the unique identifier field is getting changed to 0 during sync
906
03-02-2017 03:28 PM
TerriWebster
In Collector App a numeric field used as the unique identifier that is not editable is changing to 0 during the sync process on just some of the records. Why would this be happening?
by Anonymous User
Not applicable
Terri,
Are you using hosted feature services on Portal/ArcGIS Online or are you using services from ArcGIS Server?
If server, which version of server? What kind of database are you storing your data?(sql, oracle, other?)
Is your data archived or versioned?
are you on the latest version of Collector?
TerriWebster
The data is in a file geodatabase .gdb and published from ArcGIS Online. Version 10.4.2
by Anonymous User
Not applicable
This was published directly to ArcGIS Online? Just confirming.
