Remove map from the collector app
7504
12-30-2014 01:57 AM
HaniDraidi
How can I remove a map that I’ve downloaded  to my maps on my Android device? I cannot find a “delete” button
Thank you and Best Regards,
Hani
Kylie
by Esri Regular Contributor
I don't have that same device, but you should find Manage in the menu -- does your device have a hardware "menu" button? Try there.
Esri Education Team
LuciHawkins
You should be able to go to the "Map Gallery" look at the maps on your device and then select "Manage" and remove the map from your device.
Quick reference—Collector for ArcGIS | ArcGIS
Luci
HaniDraidi
Many thanks for the attention Luci,
I couldn't find the "manage" button; the screenshots below are taken from my Samsung Galaxy Tab 3 mini device, and there is no "manage" button appears. May you please show me where I can find it with screenshots?
Thank you again and Best Regards,
Kylie
Esri Education Team
HaniDraidi
Thank you a lot Kylie for your prompt response,
The menu button has resolved the problem and I found the "manage" button!
