Points display in Collector Classic and Explorer but not Collector
1382
08-28-2020 01:01 PM
JacobRougeaux
New Contributor III
I have several point layers that I would like to be able to use in Collector for ArcGIS with their current symbology.  The problem is they won't draw in Collector unless I change the symbology to something that is offered within ArcGIS Online.
I can use the same map and feature layers in Collector Classic or Explorer and everything displays just fine.  I've attached a couple screenshots showing this.  The symbology was created in ArcMap and the data published to Portal on a federated server.  The feature layers were then copied to AGOL using stored credentials and the web map created within AGOL.
Lines and polygons render in all three applications without issue.
RuiGe
by Esri Contributor
Hi, Jacob,
Can you provide more details about the symbol you used in your feature layer?
Rui
JacobRougeaux
New Contributor III
Rui,
Here's a screenshot of some stormwater symbology I have. The line and polygons display as they should but none of the points do. The symbology was taken from ArcMap, and there's nothing special or complex about it to my knowledge.
Jake
RuiGe
by Esri Contributor
Jake,
Thanks for the information.
Is there any Coded Value Domains associated with your point layer?
