Two part question regarding offline feature services:
I have a web map with a couple of feature services(AGO hosted, not tiled) built for collector. Only one layer has editing enabled in the web map and two(including the editable) have pop-ups, the rest are essentially "base" layers. All services have synch enabled. When I take the map offline using an Esri basemap all of the services appear and draw correctly. I have two problems however:
- Labels appear (which is great) but they only display in the center of the polygon, the label properties in the feature services are ser to esriServerPolygonPlacementAlwaysHorizontal Is there a way to adjust the label properties for the offline feature service?
-Pop-ups are enabled for every layer in the web map.... This is fairly cumbersome as it's drilling through and picking up several polygon layers. Is there a method to prevent this from happening?
We need to use the Esri Imagery service as the basemap, so side-loading a custom basemap does not appear to be an option at this time.
Thanks!
