Map Downloads with Collector Classic but not the New Collector
5035
24
04-02-2019 10:14 AM
PatrickFilyer
Occasional Contributor II
Has anyone else experienced this?
ThomasColson
MVP Frequent Contributor
Was there ever a resolution to this? We're now suddenly seeing this error on feature services that have no shared domains or field names, single feature class in the service, on new and existing services. Never had these problems with Collector Classic.
ColinLawrence
Thomas,
I dont see any indication this was ever resolved with Support. As I mentioned before I believe this has to do with editor tracking fields. Can you check the schema of your problematic service? If you have editor tracking on you should only have these 4 fields:
Editor
Creator
EditDate
CreationDate
The names could vary depending on how you added editor tracking, but there should not be any duplicates (ie. Editor_1). Let me know if you see something like this.
Regards,
Colin
Regards,
Colin
ThomasColson
We're in a bit of a pickle with Editor Tracking, as we can't track Editor or Creator as that involves collection of PII, so we only track EDITDATE and CREATDATE. However, I set the default for EDITUSER and CREATUSER as both "GRSM User".
ThomasColson
So editor tracking is the culprit. When CREATEUSER and EDITUSER both default to "Some Name", and editor tracking is turned on, the map will not download (Portal 10.6.1, Unfederated Server 10.6.1, SDE 10.7)
ColinLawrence
Thomas,
I am glad you were able to narrow it down. Would you be able to submit this to Support so a bug can be logged? This would be the most efficient way to close the loop on this issue and thread. Thank you!
Regards,
Colin
Regards,
Colin
ThomasColson
So this is back with server 10.7.1
ColinLawrence
Thomas,
Was a bug ever logged with Support? If so, could you pass along the bug number?
Regards,
Colin
Regards,
Colin
ThomasColson
No, I got side tracked, but this is happening with AGOL as well, for quite a large number of layers, so a TS case will be opened soon. Quite frustrating.
ColinLawrence
Yes, please log a case if you can. Have you been able to narrow it to the editor tracking user fields? I am wondering if it is an issue with the default value being applied. You could try defining out these fields and see if its still reproducible?
Colin
Regards,
Colin
ThomasColson
Case 02479265  if you want to see the source schema, and I've got a map up on AGOl you can repro with.
