Layers will not Load in field map or collector
945
5
02-15-2022 06:51 AM
MarlaJohnson
We have recently installed and configured Portal for ArcGIS and ArcGIS Server. We published the data using ArcGIS Pro and created a web map, Field maps and Collector enabled. The issue is I can see the map on the Field Maps app but the layers will not load.  I have checked permission's on layers etc and it still does not work.
bryandhughes
I am having similar issues. Mine was working for awhile until I attempted to use offline mode, but now it won't show any of them again. Field Maps feels a little half baked. Is it the same for you in Collector?
emmastone0098
just here to ask you that am having same issue on my site pinterest gif downloader
MarlaJohnson
It is happening in Field maps and Collector.
by Anonymous User
Not applicable
One layer must be editable. I had that issue before as well.
MarlaJohnson
I figured it out. It was a networking issue.
