Labelling working in Collector, sort-of..
4087
09-22-2014 05:57 AM
PeteCrosier
Occasional Contributor III
I’ve actually discovered a scenario where labels do work in Collector (though I’m not sure why):
  • Turn labelling on for a simple line file geodatabase feature class in ArcMap 10.2.1
  • Publish the feature class as a service through ArcMap to AGOL
  • Add the published / hosted features to a web map in AGOL – the layer in the web map doesn’t have labels enabled
  • Download the web map and data in Collector for offline usage
  • Capture a new line feature offline and the label will appear
So Collector can do some sort-of labelling, any idea when this will be extended?
BarryBiediger
New Contributor III
Any news on this?
Thorbjørn_VangSøndergaard
New Contributor II
Read this one: labeling point feature layer (feature service) in Collector for ArcGIS
That answers it - kind of...
But still: The whole issue about missing labeling on hosted feature services in Collector is a big lack of standard GIS-functionality. And it doesn't seem to have been fixed in the new 10.3 version.
Come on ESRI! What's the problem? If it (unfortunetly sometimes) can work with offline maps, then I suppose it is possibel to make it work all the time.
