labeling point feature layer (feature service) in Collector for ArcGIS
3882
10-12-2014 01:08 PM
RichardHughes
I've put together a great workflow for a client of mine to collect data inside of an airport on multiple floors.  I've been reading about labeling not being supported in Collector and I am hoping to get clarification on what that means.
We can create a web map with point feature layers that have labels enabled.  When we download the web map to collector, the labels do show up next to the points.  This is a critical part of how maintenance crews will be verifying data as they can see the id number of a point before selecting it.
Sometimes the labels do not show up when downloading a new 'saved as' web map.  Do you guys know what would cause the labels to show up in the first place?  It seems like they are supported, but I cannot find documentation to fix the issue when they do not show up.  If we knew how to replicate the environment that exists when they do show up then we can work on supporting them?  IDK
DavinShokes1
Occasional Contributor II
For some silly reason labels only work in offline mode; when users have downloaded the base map and features. Collector reads labeling rules for a layer from a file stored on the device. If only normal maps would cache the config json files and Collector labeled consistently.
I Assume that your new web map is missing a step in the overly complicated offline preparation.
