Is it possible to pair a Trimble R6 with Collector and have it populate GNSS fields?
505
06-05-2019 08:53 AM
JacobRougeaux
I am attempting to pair an R6 for use in Collector for Android and am trying to determine if I have hit a dead end.  I can achieve centimeter accuracy using GNSS Status, but it only works in Collector if I keep the Provider set to Integrated.  Therefore, the GNSS fields do not populate when I collect a point.  This is for a waterline project and the client is seeking highly accurate z-values that need to be documented.
If I try to switch the provider to the R6, I lose my connection to GNSS Status as soon as I open a map.  I thought maybe it was an issue with either the VRS or NMEA settings in GNSS Status, but nothing has worked thus far.
Any help or direction is greatly appreciated!
