How to modify script to get photos of collector with desire filename
1492
08-29-2021 09:15 PM
MaryamPanji
I’m trying to export attachments (photos) with area_ID at the begining.
I have a feature class, a table that has _ATTACH in its name, and a relationship class. I use _ATTACH table and http://support.esri.com/technical-article/000011912 to export photos to a local folder. The name of photos look like this:
I want to get ride of 17,18,19 and 20 but add a field from the feature class at the beginning of the photos name.
How can I do that?
The field is area_ID and I want the photo names to become like this:
The script I use based on http://support.esri.com/technical-article/000011912
The script:
import arcpy
from arcpy import da
import os
inTable = arcpy.GetParameterAsText(0)
fileLocation = arcpy.GetParameterAsText(1)
with da.SearchCursor(inTable, ['DATA', 'ATT_NAME','ATTACHMENTID']) as cursor:
    for item in cursor:
        attachment = item[0]
        filenum = str(item[2]) + "_"
        filename = filenum + str(item[1])
        open(fileLocation + os.sep + filename, 'wb').write(attachment.tobytes())
        del item
        del filenum
        del filename
        del attachment
['DATA', 'ATT_NAME','ATTACHMENTID'] all these fields are in -ATTACH table and I want to add the area_ID instead of 'ATTACHMENTID' which is in the origin feature class.
DougBrowning
This is the way.  Just do a join then you can grab the other field.  I do it like this.
# to get the names and PrimaryKey
photoForm = "Photos"
# actual attachements table
attachName = "Photos__ATTACH"
outDir = r"C:\tmp\Photos"
# should be standard
fldBLOB = 'DATA'
fldAttName = 'ATT_NAME'
dateLoadedInDb = "2020-09-01"
# vars--------------------
print "Starting"
# join to  form to get the PrimaryKey and state info
# Note the first year they called it PlotKey instead
arcpy.MakeTableView_management(inDB + "\\" + attachName, "attachView")
arcpy.AddJoin_management("attachView", "REL_GLOBALID", inDB + "\\" + photoForm, "globalid")
# funky due to the join
fieldList = [attachName + "." + fldBLOB, attachName + "." + fldAttName, photoForm + ".PlotKey", photoForm + ".Office", photoForm + ".filename_T1", photoForm + ".filename_T2", photoForm + ".filename_T3" \
            ,photoForm + ".filename_Soil", photoForm + ".MiscPhoto1filename", photoForm + ".MiscPhoto2filename", photoForm + ".MiscPhoto3filename", photoForm + ".MiscPhoto4filename", photoForm + ".MiscPhoto5filename"]
with arcpy.da.SearchCursor("attachView", fieldList) as cursor:
   for row in cursor:
      binaryRep = row[0]
     # full access to fields here
David_Brooks
MVP Regular Contributor
Off the top of my head, you need to create a field in your attachment table into which you'll copy your feature class name values. Then you. Wed to add a table join between the FC Global ID and your attachment tables RELGLOBALID and then field calc the values across. Then you can rename your attachments accordingly via your script
David
..Maps with no limits..
DougBrowning
fldBLOB = 'DATA'
print "Starting"
   for row in cursor:
      binaryRep = row[0]
MaryamPanji
Thanks David and Doug,
Yes, I created a view and used join as you suggested and used the script above with a minor change, as I wanted the script creates a folder based on area_ID. I put my final script in case someone wants to create folders for records for each site: with the below script you don't need to create a script tool. Just open arcpy in arcmap and run it.
#import arcpy
import os
arcpy.env.overwriteOutput= True
photoForm = "SiteVisits"
attachName = "SiteVisits__ATTACH"
outDir = r'\\GIS\geo$\G\Temp'
def create_dir(filename):
    if not os.path.exists(os.path.dirname(filename)):
        try:
            os.makedirs(os.path.dirname(filename))
        except OSError as exc:
            if exc.errno != errno.EEXIST:
                raise
print "Starting"
arcpy.MakeTableView_management(attachName, "attachView")
arcpy.AddJoin_management("attachView", "REL_GLOBALID", photoForm, "GLOBALID")
fieldList = [attachName + ".DATA", attachName + ".ATT_NAME", photoForm + ".Area_ID", photoForm + ".created_date"]
   for row in cursor:
        binaryRep = row[0]
        filenum = str(row[1])
        filename = r"{}\Photos\{}\{}".format(outDir, row[2], str(row[3])[:4] +"_" + filenum)
        open(filename, 'wb').write(binaryRep.tobytes())
        del row
        del filenum
        del filename
        del binaryRep
