How do I edit my AGOL map in ArcGIS for Desktop?
885
12-01-2016 09:57 AM
MarkButler1
I am mapping a sewer utility by first using collector and AGOL map to field locate the manholes first.  I want to add in sewer pipes in on ArcGIS for Desktop to creat my sewer network.  How do I edit my AGOL map in ArcGIS for Desktop?  When I connect to my AGOL map and try to edit it, it says it wont allow editing.  Is there a setting i missed somewhere?
MichaelMiller2
You should publish a map document to AGOL with your pipes and then add that layer to your AGOL map used in collector.
by Anonymous User
Not applicable
Check out the Help article "About editing data from feature services".  You basically make a local copy of the data in ArcMap, make your edits, and then sync back to the service.
