I have an AGOL map where we are field locating all the manholes in the sanitary system using Collector app. Each manhole was inspected. The manhole feature class has attribute info for pipes such as invert, direction, material, diameter. I now want to draw in the sewer pipes to connect the manholes in an ArcGIS for Desktop edit session. What is the simplest way to associate or transfer the pipe related attributes from the manhole feature class to the pipes? Has anyone run into this issue before?
You might take a look at the Attribute Assistant add in:
Attribute Assistant | ArcGIS Solutions
There are three methods that come to mind to aid in what you are after: intersecting feature, nearest feature, nearest feature attributes
All methods - Attribute Assistant | ArcGIS Solutions
