How can I record field worker's current position in and enterprise database using Collector?
52
01-17-2020 07:50 AM
KristinVernon
So my situation is that I would like to pin-point a field worker's current location at the moment they are collecting data using collector.
Currently my layer which Collector is using is in an enterprise database, I would like the coordinates for the field worker's current position to also be included in the same database.
I've been reading about the Location Tracking layer but I couldn't figure out how to bring it into my database. If there is a way where I can bring the Location Tracking layer from my portal into my enterprise database, I'm open to that solution.
Otherwise, an alternative I was trying to figure out is to be able to record the current location of the device by default upon collecting the data, but without allowing the field worker to change this value.
Reply
