Hello, I am currently trying to set up some hosted feature layers that I imported from a file geodatabase to be used inside collector. I have been able to format the fields how I like for the most part but for some reason, the fields I have set up with a domain are not displaying a dropdown when brought up in collector, but instead accept the code values when inputting data and show the description associated with the code after hitting next. I was wondering if there is some setting I am missing or something to enable the dropdowns.
I have attached 2 screenshots to this, one shows what the field looks like when I'm inputting data and the other shows the field after hitting next. I am assuming I am missing something simple, and could use some help.
Thanks!
