Field Added on ArcGIS Online Does not Appear on Collector
2362
10
07-05-2018 06:16 AM
PatrickFilyer
Occasional Contributor II
I have added a field to feature layer hosted on arcgis online using the agol add field button. This field does not appear on collector despite setting it to be editable.
is this a known bug?
RandyBurton
MVP Alum
Did you check the map's pop-up display settings?  You may need to check the display and edit boxes as this may not be automatic when adding a new field.
PatrickFilyer
Hey Randy,
Thanks for the response. I did check this setting in order to make it editable.
RandyBurton
MVP Alum
And the box for visible is also checked?
PatrickFilyer
yup
RandyBurton
MVP Alum
And the Collector map was refreshed?
PatrickFilyer
yes it was
RandyBurton
MVP Alum
Puzzling.  And the map works as expected on AGOL?  Is the field name unusual, a reserved SQL word or something?
PatrickFilyer
Yes it works in AGOL. The field name is License so I don't think that should mess it up.
KarinaLivingston
I know this is an old post but I am experiencing something similar. I see the field when I click on the point but when I hit edit, the field disappears. It's set to edit in the pop-up. It works in the Collector Classic app but not in the new Collector for ArcGIS.
