Export attribute table to excel with photo attachments
21481
28
12-02-2014 12:33 PM
NicholasMartin1
I am using Collector on a project that relies heavily on photo attachments. Viewing the photographs of collected data points in ArcGIS Online is working well, but I also want to share these photo attachments in other formats.
Specifically, I want to export an attribute table to a spreadsheet with photo attachments viewable on the spreadsheet (or create a report from ArcMap with these photo attachments). I also would like to be able to share feature classes in ArcMap that include photograph attachments. However, I haven’t figured out how to achieve either.
When I export ArcGIS Online feature classes to ArcGIS for desktop, the attachments are viewable in the attachment manager for each point. If I try to export the feature class to share with another party, however, the attachments are lost. Similarly, when I export the attribute table to a spreadsheet the photos aren’t viewable.
So I have two questions:
  1. 1) Is it possible to easily share feature classes in ArcGIS that include photo attachments?
  2. 2) Is it possible to include photo attachments when I export an attribute table to a spreadsheet?
Any help or guidance is appreciated. Thank you!
Tags (1)
JessicaThompson
Were you able to get multiple pictures to show up?
I keep getting this error.
AlinaTaus
Hi Jessica,
I can get more than one attachment but I can only show one per asset in the report. So in the second picture that I posted above you can see the same asset (Facility ID= 1221) shows up twice in the report because there are two attachments for that one asset.
Does your report run if you only have one attachment?
Alina
JessicaThompson
So, you did your join to your attachment table?  How did you get them to show up?  I have up to 4 pictures per point...
That did work!
Thanks!
AlinaTaus
Yes, I joined the feature class to the attachment table to accommodate for the Many-to-one relationship.
Then I exported to a new table and added a new text field. I used field calculator:
"<Common path to the folder that stores your exported attachments after running the script" & [ATT_NAME]
So your full path will look something like: \\C\Data\Photos\Photo1.jpg
Another thing I did was modify the script so that the Asset ID would be included in the name of the exported attachment. So instead of Photo1.jpg I had 1234_Photo1.jpg
The AssetID is stored in my feature class so that field comes over when I create the join. Then the expression looks something like:
<Common path> & [ASSETID] & "_" & [ATT_NAME]
Hope this helps!
Alina
TJKeiran1
Hi Alina,
Thanks for providing direction on using the attachment manager reporting capabilities.  Were you successful in getting all attachments associated with one record to show up as one report item?
AlinaTaus
Hi TJ,
No, unfortunately I have not been able to figure that out. If I do, I will make sure to post the solution here.
Alina
PascualBenito
@Alina.Taus: With regards to getting multiple attachments to display I saw in the Report Designer documentation that you can have sub-reports based on related records:
Reports can have multiple related reports, and likewise, you can include related reports within another related report (as long as the data source participates in a relationship).
Source: ArcGIS Help (10.2, 10.2.1, and 10.2.2)
So I was thinking that perhaps you can figure out way to have your photo URL's structured as  1-to-many related records as opposed to a 1-to-1 join and then have each photo show up as a sub-report within the main report for each feature.  (I have not done this and have not seen an example of how the related reports appear on the page.... so really this is just a possible approach that you could look into).
AlinaTaus
Hi Pascual,
Thank you for the suggestion, I will have to look into that.
Alina
SarahRijneke
Hello, I see that most of the replies in this thread are almost 10 years old! I'm wondering if anyone has an updated workflow using ArcGIS Pro. I would like to create an excel table or report with feature attributes & attachments (photos). My dataset has been downloaded from ArcGIS Online and archived so it lives in a stand alone geodatabase.
