Error: "No collectable layers are visible" when trying to create new point on mobile device.
3964
04-08-2015 02:15 PM
deleted-user-9zlChDJzM-SF
I have enabled a layer in an Enterprise Geodatabase to be editable, I have enabled editing capabilities when publishing the service, and I am able to create new features inside of a webmap. However, when I try to create a new point using my Iphone, it tells me that no collectable layers are visible. Is there a setting that I am missing to allow collecting on a mobile?
And by editable I mean create, delete, and edit
RussRoberts
Esri Notable Contributor
Also make sure you are within the visible scale range for that feature.
ShawnHibbs
Yeah, I was in the visible scale range. But there were bad thunderstorms all day long and I think that was the issue because it is working now that it has cleared up. I guess you can't create a point at all if your location is enabled and you don't have good satellite coverage. Even if you just want to create the point manually.
