Descriptions rather than codes being recorded for coded value domains
3642
05-22-2015 03:45 PM
LorettaWinton
How do I make the fields store the code of a coded value domain rather than the description? It is happening with both text and integer coded values. Also it does the same on iOS and on AGOL.
RussRoberts
Esri Notable Contributor
The apps will display the description but the code is stored. If you export your data by csv from AGOL you will see the coded values instead of the descriptions.
Russ
Todd
My reply was intended for Russell Roberts​, sorry about that
Regards,
Todd
Todd
In the Collector UI Is it possible to set the preferred output to show the coded value versus the description? Ex: Coded Value = "Yes" (or "Y"), Description = "Yes, the condition is present."
Regards,
Todd
RussRoberts
Currently there is no way to configure this. Right now the app will only display the description.
