Creating a Tile Package Larger Scale than 1:1128 for use in Collector
5163
7
09-30-2014 11:36 AM
StaceMaples
Occasional Contributor III
I've created a custom 1:1128 tile package for use in Collector, but I notice that I can't zoom in a far using MY tile Package as I can on the downloaded basemap from AGO, even though when I indicate the "Level of Detail" in the download dialog, it shows that I am downloading the AGO Basemap at 1:1128.  Can anyone explain this behavior, and how I can get the same zoom levels? The Share>Tile Package wizard doesn't seem capable of higher than 1:1128. Is this overzooming? If so, can I not do the same with MY tile package?
RussRoberts
Esri Notable Contributor
Can you right click on the tpk, then click on 7 Zip > Open Archive. See if your folder has a servicedescriptions folder and open up the file inside of the folder.
You will see a section in the JSON that will look like this:
       "minScale": 36111.909643,
        "maxScale": 1128.497176,
        "units": "esriMeters",
        "supportedImageFormatTypes": "PNG32,PNG24,PNG,JPG,DIB,TIFF,EMF,PS,PDF,GIF,SVG,SVGZ,BMP",
        "documentInfo": {
            "Title": "",
            "Author": "",
            "Comments": "",
            "Subject": "",
            "Category": "",
            "AntialiasingMode": "Best",
            "TextAntialiasingMode": "Force",
            "Keywords": ""
The bold text shows the min and max scale for the tpk. I generated a test case with just a tpk with data and was able to get dow to the 1128 level. If you are missing a file or if those numbers a 0'd then there could be an issue when the tpk is being generated.
StaceMaples
SPOT ON, Russell! Here is the referenced section from the JSON:
    "minScale": 0,
    "maxScale": 0,
    "documentInfo": {
      "Title": "",
      "Author": "",
      "Comments": "",
      "Subject": "",
      "Category": "",
      "Keywords": ""
Any idea what would cause/how to troubleshoot that?
RussRoberts
What version of Desktop are you using? I was using 10.2.2 when I created that sample tpk to generate that JSON above.
StaceMaples
Same. 10.2.2. All the data is local.
StaceMaples
What happens if I just change those values?
RussRoberts
I haven't tested out changing the values with a tpk that has given me an output of 0,0 but it should work if you set it to the correct min and max of your tpk.
JssrRR
Creating a Tile Cache or Package that is Visible at All Scales
Here is a complete workflow for getting the results you are looking for.
