Configure Collector app to require admin verification of edits?
447
01-14-2021 06:13 PM
BK710
Hi I'm new,
I made a Collector app and need to configure the settings such that edits that are made in the field undergo review before they update the webmap/feature service, or become available to the rest of the group/org. Ideally a field worker's edits will require approval after they sync - please share any links to information regarding this part of the Collector workflow !
LongDinh
Occasional Contributor II
Hi bethkahrer,
You may be looking for 'versioned data' if you are looking into reconciling changes to a master/authoritative dataset.
It might not be possible in Collector (as I have not worked with Collector for some time now) but a possible workflow could be to:
  1. Create a versioned dataset and publish it as a feature service,
  2. Create a version for user editor (e.g. a version named: "EditorDataset") in your database,
  3. Create a web map with the EditorDataset versioned feature layer,
  4. Share the web map as a  collector application.
From there, when edits come in, they can reconcile on the desktop or through a version management service.
Here are some links for working with versions on REST and Collector.
https://developers.arcgis.com/rest/services-reference/version-management-service.htm
https://enterprise.arcgis.com/en/server/latest/publish-services/windows/offline-maps-and-versioned-d...
Good luck!
