Collector Offline Download Error
393
08-08-2017 03:20 PM
VikramS
I have a webmap which has editing layers coming from ArcGIS Data Store and the Reference Layers coming from ArcSDE which is non versioned, Archiving Enabled and has GlobalID field.
When I try to go offline in Collector. It Fails and says "Failed to create a replica"
When I try to create a replica using Rest End Point it fails if I include Layer ID 3 . If I don't include then the replica is successful. So when I tried to remove the layer from the webmap. Now I can go offline.
I tried to publish layerID 3 as a separate service and added to the same map. Offline download was successful.
I am not sure why it is not working when the layer is in the same service ? Any ideas?
Please Note:
Reference Feature Class in SDE are inside Feature dataset.
Recreated all feature class with new name , non versioned, Archiving Enabled and has GlobalID field. Still not working.
