Collector not posting attachments and ObjectID out of sequence
4260
04-10-2015 06:00 AM
BrookeGajownik
When I take a picture and submit it with my form in Collector, the attachment says it posts, but it does not show in the database.  I have the database set to accept attachments.  It will accept them if I manually add the attachment in Desktop, but not from the ipad or iphone.  It also adds an ObjectID that is not consistent with the previous  entries (example: 3, 4, 5, 6, 7, 401, 1201).  Any help?
BrookeGajownik
webadaptor SSL issue resolved.
MatsHallen
Hi Brooke
I have the same experience with my service. When I load pictures from ArcMap on my Server everything works fine and the picture is saved as a blob in the attached table
But when I try to upload picture through collector I cant find it anywhere in the database.
Id appreciate your help
Kind regards
Mats
BrookeGajownik
Hi Mats-
We had to go into the IIS on the web adapter for that virtual directory and ignore the client certificates.   For some reason, they were set to 'accept' and after doing some research, we determined this was the cause.
As far as the OID's being out of sequence, that seems to be its own, partially related beast that we are trying to trouble shoot.  I hope this helps and finds you well!
Brooke
Leif_RuneUlle
Hi again and thank you for the answer
It seems like we have to different issues.
I needed to create attachments on a feature class that is placed outside a feature dataset...
Kind Regards
Mats
