I'm using a collector link like so:
https://collector.arcgis.app?itemID=<webmapID>¢er=34.0547155,-117.1961714
The web map opens and pans to the location like it's supposed to. However a pin icon isn't dropping on the location like it used to. I've only seen this in iOS so far. Here's an image in Android with the correct behavior using an arcgis-collector:// link
For anyone that might see this. An "equivalency bug" report was created by support. It's Bug# is BUG-000129559
Hi Mitchell,
The app link scheme that you are using is not supported with the released version of Collector on the Android platform. It is however with the beta version. We are very close to releasing the beta version (ETA is end of March). you can join the Early Adopter program here or download the beta directly from Google Play here and give it a try.
Please let us know how you make out with the beta version!
Jeff
The issue is with iOS. Android is working fine.
