I'm running into problems when using Collector on IOS. The app has started to crash and close down when in general use - there doesn't seem to be a common function that causes this.
I'm using the app to conduct inspections on watercourse assets and save pictures.
Does anyone have any idea why its crashing and is there anything I can do to stop it?
Cheers,
Ross
Ross,
What version of Collector are you on? Are you also on the latest version of iOS?
Is there a certain task you perform in Collector (make an edit, pan/zoom, create a point) where Collector will crash?
It is hard to say what specifically could cause Collector to crash. Are you using services from ArcGIS Server or services that you published directly to ArcGIS Online?
Hi Dan,
I have a similiar issue with ArcCollector v10.4.2 - ios version 10.3.2
The Collector app started crashing since last week - used to work fine previously.
When we try to load the app in the mobile, the app tries to load and crashes - have to open several times to load the published maps - not sure on the root cause?
Was there anything done to the service last week? Are you using services from ArcGIS Server or services published directly to ArcGIS Online/Portal?
Are the services secured? Are you opening an offline map or online map?
Makhesh,
Does your data use a specific projection?
GDA94 - MGA Zone 56
