Collector for ArcGIS Problem
861
05-31-2017 11:31 AM
DavidSchaab
My Collector for GIS App is installed on my Samsung Android tablet.  I have downloaded a map to use offline with a custom base map but when I tap on the map I get nothing but a spinning circle.  What could be some of the causes of this problem?
Tags (1)
TiffanyRufo
Occasional Contributor II
I would suggest checking to see if you have a wifi or cellular data connection and checking to make sure that the map is shared with the group that your login is a member of. If the maps aren't shared with the right groups they won't show up. Same for a lack of wifi or data connection.
Those are the issues that I have had before. I will post others if I think of them.
Hope it works out soon!
DavidSchaab
Although I have already downloaded the map for offline use, I am still connected to a strong wifi connection while trying to open the map.  The map is showing up on the Collector App on the tablet so I assumed it has been shared with the appropriate users, but I just double checked and the map has been shared with the appropriate group that my login user is a member of.
Thank you for keeping this issue in mind!
DavidSchaab
I am still having the same issue, I can provide video if need be.  Could it be possible my Collector settings are wrong?  If so, what should my settings be?  I am using the GPS built in to my device, no external GPS receiver to obtain high-accuracy data (yet I am still getting a message about NMEA).  In the location settings my location provider is an Integrated receiver with an antenna height of 0.00m, should this be an actual number?  Please help.
RandyBurton
MVP Regular Contributor
You mentioned a "custom basemap."  Does the map work offline with a different basemap?
DavidSchaab
I did not try this; I ended up taking the tablet back to factory defaults, loaded everything back on and that seemed to work.
Next time one of my tablets has this issue, I will try using a different basemap than my custom one and let you know if this works.
