Collector for ArcGIS for iOS (iPad) - Can't add inspection record to related table (with no geometry)
522
08-23-2018 11:32 AM
BurkeThompson
I have a Collector App set up for Inspecting Storm Water Management Ponds. Each pond is represented in a polygon layer and is related to an inspections table (1 to many). Both the pond layer and inspections table are in Oracle, related via ArcGIS Catalog and published as a feature service in ArcGIS Server 10.3.1.
Using an iPad, I am unable to add an inspection record related to the pond. In the pop-up window for the storm pond, when I click 'New', the app tries to get a GPS fix for the new record, even though the table has no geometry. The app will not accept the new inspection record citing “Valid Location Required - Collect a location by using your current position or tapping on the map”.
Note: The workflow works perfectly on an Android device, but my customer uses only iPads.
Burke
