Collector - Error when trying to download a map on Android
620
08-08-2018 12:26 AM
Environnement_1Lausanne
When I try to download a map for a Collector App on an Android device, I get the following error message : "Read error: ssl=0xce25a880: I/O error during system call, software caused connection abort."
When I download a map with a size of about 10 MB everything works fine, but when the size gets larger, it crashes.
Do you have a solution for this problem ?
Thanks a lot !
by Anonymous User
Not applicable
I am experiencing the same issue. Have you been able to work out what the problem is/was?
Reply
Hello Jessica,
No I haven't found a solution to this issue.
Reply
SomrongSomphous_Monita
Hello Everyone
I also have a problem them you about the error message: "Read error: ssl=0xce25a880: I/O error during a system call, software caused connection abort. because the Collector app has two like Collector for ArcGIS and Collector Classic so the solution of it ->Please go through to Your MAP -> Setting ->  Office page -> Manage Area-> Choose area Size as you want then Save it complete. #arcgisonline
Reply
