Collector - Create Dropdown menu from table of addresses?
3984
06-09-2016 09:44 AM
NoahWasserman
New Contributor III
I need to field verify 400+ addresses and collect data at each.  I would like to create a drop down menu of all my addresses as I have them listed in my database so I can maintain IDs and data continuity.  Is there a way to populate a collector drop down list for a large number of options from a table without entering each manually when setting up my geo-database domains?  (e.g. I want to make sure I use "645-647 Main Street" as I have in my database instead of "645 Main Street" as it might appear on the building address plate).
RandyBurton
Are you sure you want a dropdown with 400+ choices?  That would probably be difficult to navigate.  If the answer is still yes, you could import your address list into a  table (using Excel to Table, for example), then use the Table to Domain tool to create a domain.  The field would then be set to take its value from the domain list dropdown.  You may want to split the address into parts for several smaller dropdowns: number part, street name, street type, etc.
NoahWasserman
New Contributor III
We have a lot of multiple address buildings that are screwing up our survey/database so I want to make sure the address/building ID is exactly what we have in our database when we field verify.  We will test your recommendation and see if 400+ is too much.  Thank you!
RandyBurton
Once you get your addresses into a domain, you may want to use the Sort Domain tool to better organize the domain.  You can sort by codes or by descriptions.
by Anonymous User
Not applicable
We do periodic inspections at our facilities. I ended up creating a relationship between our facilities feature and our inspections feature. So when I look up my facility I can see all the inspections done for the facility. This would work well for you since you since you already have a table with all the addresses and IDs. Some more information on relationships. https://blogs.esri.com/esri/arcgis/2015/02/18/related-tables-exploring-new-ways-to-use-collector-for...
But you could also manually do a domain setup. Here's a good writeup from ESRI for domains..
Prepare your data in ArcGIS for Desktop—Collector for ArcGIS | ArcGIS
Good luck!
