Can't find "Advanced Options" for Hosting Feature Service to Create Versions for each Map
553
08-06-2019 02:59 PM
SarahFox1
New Contributor III
Good afternoon!
I've been trying to make an online map that our field workers can edit off of our versioned data.
Following these instructions, it says during publishing, I need to click on "Advanced Options" to then click on "Create a version for each".  However, there is no Advanced Options button anywhere!  I've tried it in ArcMap and ArcPro, trying to push the service to both Portal and AGOL, and none of the times, in any of the tabs, has ever had an Advanced Options.
Is there something I'm missing, or a different way of getting versioned data to work?  I've included screenshots of my hosting in ArcMap and Pro, to see if I'm just even doing it wrong from the beginning?
Thank you so much for any help!
JimLugosi
New Contributor III
Hi Sarah, were you able to solve this mystery?
