Can I populate an Attribute Field using features spatial location in Collector?
305
10-14-2018 03:43 PM
BenVan_Kesteren1
Hey,
I am currently using pulldata in my Survey123 setup in order to fill in an address field.
pulldata("@geopoint",${point_location},"reversegeocode.address.Match_addr")
Is it possible to set this same setup in Collector? I would like to create a polygon in Collector and the centroid pre-fill an address attribute.
Has anyone found a workaround for this?
