Are the Arcade FeatureSet functions supported in Collector?
2961
36
03-01-2019 11:39 AM
KevinMayall
Occasional Contributor II
I have created Arcade expressions that display pop-up data from a related table using FeatureSets.  They work in ArcGIS Online but not in Collector.  Does Collector (the new iOS version) support FeatureSets?
MarkEastwood
New Contributor III
Got it working.
Just incase anyone runs into this post and is wondering I ended up needing to wrap the $feature.globalid with the Upper() function. The character values in my GlobalIDs were returning in lower case in Field Maps but the actual GlobalID values have upper case characters.
var sql = "rel_globalid = '" + Upper($feature.globalid) + "'";
var tbl = Filter(FeatureSetByName($map,"Bridge Attributes", ['*'], false), sql);
var val = ''
for (var row in tbl){
    val += row.client_name
return val
DougBrowning
MVP Frequent Contributor
Same question.  I switched mine to use $map so it theory it should work.  But I just get blank.
if ($feature.EvalStatus == "Eval") {
var sql = "PlotKey = '" + $feature.PlotKey + "'";
var tbl = Filter(FeatureSetByName($map,"GAP"), sql);
var txt = ''
for (var f in OrderBy(tbl,"LineKey")) {
txt = txt + Right(f.LineKey,1) + '-'
txt = Left(txt,Count(txt)-1)
if (txt != '1-2-3') {
return "\nLine Number Issue! Found: " + txt
else {
return ''
else {
return ''
Thanks
Reply
MarkBockenhauer
The newest new version.. ...   if you check out this post from Jeff Shaner‌ https://www.esri.com/arcgis-blog/products/collector/field-mobility/collector-for-arcgis-beta-updates...
It mentions that that the Collecor IOS V19.1.0 beta update includes support for Arcade Expressions.
Mark
Reply
DougBrowning
Yes I am using that version.  Also tried the recent beta.
Other stuff works just not FeatureSetByName.
Also Relationship counting does not work
{relationships/1/objectid}
Reply
DougBrowning
Is it possible to access a {relationships/1/objectid} field in Arcade?
Can I access other Arcade expressions?  Like {expression/expr0} ?
I would like to have a master check like If {expression/expr0} == 1 and {expression/expr1} == 1 and etc}
Arcade will not let me use {} at all so how do i access these fields?
Thanks
MarkBockenhauer
Kevin and Doug,
I have reproduced what you are experiencing with Featuresets and also found out that is scheduled to be implemented in Esri Runtime update 6 which is in development and planned for summer/fall release.... and then the Esri Field Apps will need to be released on the update 6 runtime, so it will be a little while before we see Featureset"" functionn working in Collector.
Mark
DougBrowning
Ok thanks for the info.
What about - Is it possible to access a {relationships/1/objectid} field in Arcade?  These are simple check boxes to turn on in the web map but Collector is ignoring them.
thanks
DanteLee
Mark - any idea on approximate timeline? Are we talking weeks, months, or years?
DavidThompson6
New Contributor II
Hi Mark Bockenhauer
Like Dante Lee, I'm also wondering if we're talking weeks, months, or years here.  I am trying to develop a solution for a client and need to know if this functionality will be available to me in the coming weeks/months.
I'm trying to pass attributes to Survey123 that are derived based on a spatial intersect in a webmap.  I can do this perfectly from the desktop, but I need to be able to do this from Collector to S123 in the field, offline.
Thanks for your time!
-Dave
Reply
MarkBockenhauer
David,
Including support for Arcade featureset in runtime apps is schedule for this fall,  if all goes to plan, should be in released product Q1 2020.  (it didn't go as planned for Runtime update 6)
Mark
Reply
