ArcGIS Collector won't show location or accuracy after 10.4.0 update
20502
33
08-01-2016 04:38 PM
MatthewTwietmeyer
I updated ArcGIS Collector to 10.4.0 and now that brings with it new configuration for using a receiver. My problem now is that Collector can't fix in on my location nor give me a accuracy in ft with my Garmin GLO device. When I go to turn on my location within the map the device can't find my location. I suspect it has to do with the location profile settings, but I can't seem to figure that out. My offline map is in WGS_1984_Web_Mercator _Auxillary_Sphere. The default system is GCS WGS 1984, is there a necessary profile for the garmin glo to function?
Anyone else having this issue?
Matthew Twietmeyer
RandyBurton
Thanks jriester13‌. It looks very helpful.
ScottKiley
Thanks for the support docs Jay‌ & Gale
PankajJamwal1
I am using Panasonic Toughpad windows tablet and my collector is set for integrated receiver. The accuracy on the collector doesn't move and down and stays at 16.4 feet. I was wondering if anybody knows how to sort out this issue and what actually is causing this?
Thanks in advance.
by Anonymous User
Not applicable
Pankaj,
This geonet post may help you:
https://community.esri.com/thread/171705
