ArcGIS Collector: Why the collector is not able to access a web map?
2724
14
03-12-2020 04:17 AM
JamalNUMAN
Legendary Contributor
Despite the fact that a web map is created successfully, the collector fails to access it
What could be the issue here?
Jamal Numan
Katie_Clark
Good point, thanks for the correction Kylie Donia‌!
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Kylie
by Esri Regular Contributor
I added your layer to a new map and saved it, and I see that map in Collector.
Did you make your layer editable after you had made the map? If so, try resaving the map. There is some metadata stored with the map that doesn't get written if the map isn't editable, and that would explain a few of the things you are seeing here.
Esri Education Team
JamalNUMAN
Good Catch Kylie. Precisely. This is what I have done. The editing feature is enabled after adding the layer to the web map viewer. It appears that enabling it afterwards doesn’t resolve the issue. However, saving the web map viewer resolves the issue! It works like a charm
By the way, I couldn’t figure out where the offline option is
Jamal Numan
Kylie
As Katherine mentioned about, you don't have sync enabled on your layer. As a result, you won't be able to use it offline.
The sync setting is a bit below the Editing one that you showed in an earlier screenshot.
Esri Education Team
JamalNUMAN
Manty thanks guys for the help
Best
Jamal
Jamal Numan
