ArcGIS Collector - Related Records Title Field
841
04-24-2017 05:53 AM
CharlieDoherty
We have set up a feature service from an SDE point layer with related records in a table. The SDE layer is for collecting information on Trees with the related table layer for collecting data on inspections against the trees. In Arcmap and ArcGIS Collector when viewing existing related records for a tree the field which shows is the auto generated user field as below:
Related Record Title
I would like this to instead show the inspection date field shown in the below list of attributes. Is there any way to change which is the 'title' field in essence as this would make more sense to collectors in the field.
Inspection Date Attribute
Any help would be much appreciated, I presume this could be because this is the first text field on the list but if there is a way to show the date that would be great. Thanks in advance for any responses.
Charlie
