As we have been testing Aurora and now working with Collector 18.1.0 the number one complaint we have is the position of the Table of Contents sidebar on tablet devices. In previous versions of Collector, the sidebar was on the right and you can make all inputs from one side of the screen. The new versions the sidebar is on the left and you need to cross the screen to select your feature then back again to press Submit. If there a way to change the position of the sidebar in collector we have not found it.
This may sound petty, but when you are collecting hundreds of points a day this takes time. We have also noted, on occasion, you accidentally pan the map when moving your hand across the map and end up collecting a manual point rather than the GPS point. It took us a while to figure out where these rouge points were coming from.
Edited screen shots for graphic representation
Current Sidebar Location
Proposed Sidebar location (or option to change)
