TIFs in CityEngine 2015
4206
7
05-21-2015 09:27 PM
NathanStocker
New Contributor III
Hi All,
Is it just me, or has TIF disappeared as an option for importing height maps and textures in CityEngine 2015?
I had always used TIF to export from ArcMap and import into CE, but now it looks like I may have to change. It's slightly annoying, since the other file types don't seem to work for exporting my 32bit DEM, so I guess I'll just have to make a CityEngine-compatible version of it.
That said, I think I'll survive
Nathan
BenLeslie1
Occasional Contributor III
This all works fine for me - I'm on 2015 Advanced Concurrent.
Maybe re-install will help?
IonutAlixandroae
Hi Nathan,
You could use .IMG format for DEMs. I always do and there`s no problem.
Ionut
MatthiasBuehler
I see and can use tif files .. no issues here ..
Matt
Matthias Buehler
Head of 3D Technologies
twitter: @MattB3D
Garsdale Design Limited
matthias.buehler@garsdaledesign.co.uk
www.garsdaledesign.co.uk
NathanStocker
New Contributor III
Thanks for the help guys. Strangely, neither IMG nor TIF are showing in my 'select heightmap file' options.
I think either I'm doing something silly, or I'm missing some options that appear for you?
IonutAlixandroae
If you copy your heightmap into a folder or connect a folder in which you have the heightmap, try drag and drop it into the scene and I think it will load
NathanStocker
New Contributor III
That doesn't work either unfortunately - it just takes me to the generic import window.
I'm not sure if it's related, but I'm also having an issue with textures - in that none of them work!
Even a simple rule like the one below comes up with unknown texture. I've tried downloading example scenes and they come up with the same thing (no textures).
attr Texture = "/CapacityModelling/assets/g_f001_t006_Residential_036.jpg"
Lot -->
  extrude(world.y, 12)
  split(y){4 : Lot2}*
Lot2 -->
  setupProjection(0, scope.xy, 3, 3)
  texture(Texture)
  projectUV(0)
  Lot3.
I've tried deleting my .cityengine folder, but that didn't help. I've attached an error that seems to come up every time I open CityEngine (not sure if it's related).
BenLeslie1
NathanStocker
New Contributor III
Thanks Ben - you're on the mark. It was good just finding out that the problem was just with my own CityEngine.
I've reinstalled CE and it's working fine now
