Street direction from poly shape
2793
08-13-2015 09:03 AM
curtedmonds
Hi all,
I have several poly shapes I created in City-engine (and some from OSM) I extruded, I would like to detect the poly facing the street.
One possibility I have considered (but not sure how to implement) is to paint a map of the streets and detect if a color is near the face (this would be a street attrib)
any help from large brains, much appreciated
ChrisWilkins
In the help documents, search for this:
geometry.isOriented
This might be what you need. Please let us know if this works for you.
Chris
curtedmonds
Will try but thought this would not work if a shape was not generated from lot, as the attribute "street" would not be there for it to derive from.
curtedmonds
yes as i thought, does not work.
do you know if the mapping method will work, ie. creating a colour map of all the streets (perhaps slightly lager so a poly can sample below its position)
