Relationship of attributes in Imported Rules
213
12-21-2021 02:07 PM
MattOlsen
New Contributor II
Hi everyone,
I have a simple 'floor area' rule based on one of the tutorials that takes a extruded shape, splits it into building floors, and then creates 'floors' from the bottom face of those floors, to report floor areas.
@Enum("Retail", "Commercial", "Residential")
attr Use = "Retail"
attr floor_height = 4
Init-->
split(y){ floor_height : Floors (Use) }*
Floors(type)-->
comp(f) {bottom: reverseNormals Floors_Areas(type)}
Floors_Areas(type)-->
case type == "Retail":
report("GFA.Retail", geometry.area)
color("#ff5733")
case type == "Commercial":
report("GFA.Office",geometry.area)
color("#44ff44")
else:
report("GFA.Residential",geometry.area)
color("#4444ff")
I've imported this rule into a 'master' rule which creates the basic volumes.
In the master rule I have 2 volumes, a ground floor volume, and an upper floor volume (which should be split into multiple floors by the imported 'floorarea' script.
import floors : "SplitAreas.cga"
attr Use = "Retail"
@Enum("Yes", "No")
attr GroundFloor_Retail = "Yes"
attr groundfloor_height = 7
[script to create extrusions omitted]
GroundFloor-->
set(floor_height, groundfloor_height)
# above - I'm attempting to set the floor height used in the imported rule to the ground floor height attribute set in the master rule)
case groundfloor_retail == "Yes":
set(Use, "Retail")
floors.Init
else:
floors.Init
UpperFloors-->
floors.Init
I need to to somehow set both the value of "Use" and of "floor_height" in the imported script for the ground floor volume separately - see the attempts at doing this in bold above (this doesn't work).
In the example below, the value for "Use" (Commercial / Green) and floor_height (5) is successfully being pushed from the master rule into the imported rule and floors that creates. But for the ground floor mass, I'm trying to set the floor_height to 8, and for the use to be "Retail" / red.
Is that possible, or do I need to create a separate rule to call for the ground floor since it's height and use are different?
Clover4
New Contributor II
It would be easiest to pass the height and usage from CGA rule 1 to import rule 2 than to try an override.   How are your exports from rule 1 to 2 setup up?  Are they parameterized?
Quick edit: no they are not.   floors.Init   should be something like floors.Init(height,usage).  You will have to adjust your Init start rule to have parameters too.
MattOlsen
New Contributor II
That's it! Thanks so much Brian. I had initially parameterised this, but not correctly. Rejigged slightly and it's working like a charm.
If anyone sees this thread in future and wants a description of the working solution I'd be happy to run through it.
