Object Rotate Problem?
735
04-17-2014 10:47 PM
GucluSen
New Contributor II
I am modelling a park. I need to rail road and found it internet.
When I try to put it correct location, rotating parameter or rotating angle is inadequate. There is an other "Center Pivot" problem in smare time.
How can I put it the right location in my model? Any idea 🙂
[ATTACH=CONFIG]33188[/ATTACH]
LukeCzar
New Contributor III
Here is what you should do:
[ATTACH=CONFIG]33243[/ATTACH]
Lukasz
GucluSen
New Contributor II
Lukasz
Hi Lukas,
Thanks for your answer.
Problem is the model can not rotate a little bit, it rotates 30 degrees etc but I need to rotate 12 degrees (for example)
And center pivot of the model locates irrelevant location. So, I can not rotate sensitively.
I have installed latest release a few days ago. I have not encountered a situation like this before.
I don't know, Is this the reason could be? Do you have tried to test latest release?
MatthiasBuehler1
Hmm.
The geometry editing tools are not that advanced yet.. Can't you edit/clean those geometries better in ArcGIS / CAD ?
I guess the big problem is that this shape is huge. [Means the transformation gizmo is usually shown at the centroid of the shape.] Maybe try to cut this polygon up in smaller chunks.
Also, use the text field in the middle of the tool bar to rotate by a certain amount of degrees. e.g. '0 15 0'
Let me know ..
matt
