Matching object's front elevation with a street segment | inscribed rectangle
1524
10-06-2021 06:15 AM
aginside_out
I hope that the image clearly shows what I have been trying to do.
-> I have an urban block, divided into separate lots, and would like the buildings to be created on each so that the front elevation matches the street segment orientation.
So far, I tried with this piece of a code:
BaseArea -->
reverseNormals()
innerRectangle(scope) {shape : Lot |
remainder = JustGround}
### Rules
@StartRule
# divide the block into 2 parts: Lot and JustGround.
BaseArea -->
reverseNormals()
Lot -->
case isBuildingType(0):
print("total area = " + geometry.area)
splitArea(x) { ~1 : splitArea(z) { '0.5 : Red
| '0.5 : Yellow }
| ~1 : splitArea(z) { '0.5 : Turqoise
| '0.5 : Cyan }
| ~1 : splitArea(z) { '0.5 : Blue
| '0.5 : Magenta }
case isBuildingType(1):
print(geometry.area)
splitArea(z) { '0.5 : Pink
| '0.5 : Blue }
else:
splitArea(z) { '1 : Pink }
Red --> // red
BuiltupArea
//SHOP
Yellow --> // yellow
BuiltupArea
//HOUSE
Turqoise --> // green
Garden
//GREENERY
Cyan --> // cyan
BuiltupArea
//HOUSE
Blue --> // blue
BuiltupArea
//HOUSE
Magenta --> // magenta
BuiltupArea
//HOUSE
Pink --> // semi-transparent pink
BuiltupArea
//HOUSE
# Divide BuiltupArea into an O shape: the area of O shape is FootageA; the remainder is Garden.
BuiltupArea -->
shapeO(FrontDepth,RightWidth,BackDepth,LeftWidth) {shape: FootageA|remainder: Garden}
FootageA -->
split(x){~15:FootageB|{~8:FootageC|~15: FootageB}*}
# split FootageB by z axial into 2 parts: FootageD and FootageE. FootageE is the OutHouse. FootageD is the Building.
FootageB -->
split(z){~10:FootageD|{~5:FootageE|~10: FootageF}*}
FootageC -->
Garden
# extrude FootageE
FootageE -->
case FloorNumber > 1 :
extrude(FloorHeight)OutHouse
else : Garden
# extrude FootageD
FootageD -->
case FloorNumber < 2 : Ground
case FloorNumber > 3 :
extrude(FloorHeight)Building
else : extrude(Height-FloorHeight)Building
# extrude FootageD
FootageF -->
extrude(Height)Building
...and the script goes on. I have read about two options of fitting the rectangle (that is meant to be the building footprint) into a polygon (which is the shape of my lots) -> innerRectangle(scope)  and innerRectangle(edge). I do wonder whether there is any other solution that I may apply to the project.
Have a nice day!
