I need to download rules that represent sports fields
2739
13
10-01-2019 08:57 AM
nadiatrigui
New Contributor II
I am creating a 3D city, I need to model sports fields (football, tennis, Golf course pisscine ....) I can not find the rules to represent these types of sports equipment, I used the SOCCER FIELD rule in the DESERT CITY package, but it only contains soccer fields. Can you help me please.
nadiatrigui
New Contributor II
I have the same problem
Luiz_AmadeuCoutinho
Occasional Contributor III
Hi
Why not create your own rule?
The Desert_City_Soccerfield.cga it´s it´s a basic rule that use one .jpg to show the Field, one .obj to show Goals and another to show Balls.
Try copy the rule and change the assets to your data. Search on Google for tennis field textures or Golf Course, you will find a lot of samples. 🙂
* Author: matt, Esri R&D Center Zurich
version "2013.1"
attr Orientation_Change = false
attr Goal_Back_Distance = 1.8
attr Goal_Width = 6
attr Goal_Height = 2
attr Goal_Depth = 2
attr Number_Balls = 7
// put your assets on assets Folder e change the file names
soccerFieldTex = "assets/soccerField/soccerField.jpg"
goalAsset = "assets/soccerField/soccerGoal.obj"
esriBall = "assets/soccerField/esriBall.obj"
goalEdgeID =
case Orientation_Change :
else :
UV_Rotation =
else :
90
@StartRule
SoccerField -->
Goals
Balls
setupProjection(0, scope.xz, '1,'1)
projectUV(0)
rotateUV(0,UV_Rotation)
texture(soccerFieldTex)
Field.
Goals -->
PutGoal(goalEdgeID)
PutGoal(goalEdgeID + 2)
PutGoal(edgeIndex) -->
alignScopeToGeometry(yUp, 0, edgeIndex)
split(z) {Goal_Back_Distance : NIL | 0.05 : GoalStripe | ~1 : NIL}
GoalStripe -->
s(Goal_Width, Goal_Height, Goal_Depth)
center(x)
i(goalAsset)
Goal.
Balls -->
scatter(surface,Number_Balls,uniform) { PutBall }
PutBall -->
i(esriBall,yUp,keepSizeAndPosition)
t(0,'0.5,0)
r(scopeCenter, rand(360), rand(360), rand(360))
Ball.
nadiatrigui
New Contributor II
Hi
Thanks for your respone. I Did what you describe. I tried to change files and keep same names to not be obliged to change the rules code and this is the result
nadiatrigui
New Contributor II
thanks so much Luiz Amadeu Coutinho , finally it works
Luiz_AmadeuCoutinho
Good to know
Here a CGA for tennis field using a Collada File from 3D Warehouse. It´s another simple solution.
* Author: ..., ...
//change de CE Version here
version "2019.1"
tennisFieldTex1 = "assets/tennis_court/model.dae"
UV_Rotation =
else :
90
@StartRule
TennisCourt -->
setupProjection(0, scope.xz, 0,0)
projectUV(0)
//alignScopeToGeometry(yUp,90,0)
alignScopeToGeometry (yUp, any, world.lowest)
i(tennisFieldTex1)
Field.
TH1
New Contributor II
Hi Luiz Amadeu Coutinho,
i have the problem, that the Soccer field (a model out of the 3D Warehouse) isn't right displayed.
The Orientation_Change doesn't work.
I used the following code:
soccerFieldTex1 = "assets/Sport/Fussball.dae"
UV_Rotation =
else :
90
@StartRule
Soccerfield -->
projectUV(0)
i(soccerFieldTex1)
and it looks always like this:
Is there an option to turn the soccerfield.dae?
Thank you .
Luiz_AmadeuCoutinho
Hi TH
Comment using // in the front of
And try again.
Here more info and options alignScopeToGeometry operation—CGA | Documentation
TH1
New Contributor II
Hi Luiz,
thank you for the reply.
I finally got it. I had to change the Edge Index.
Soccerfield -->
setupProjection(0, scope.xy, 0,0)
projectUV(0)
alignScopeToGeometry (yUp, 0,1)
i(soccerFieldTex1)
Javier_JovannyLeija
New Contributor II
Hello Luiz,
I was able to reproduce the field, but couldn't get the ball or the goals to come out in the image. They still are unknown objects.
Here is the code I used.
* File: Soccerfield.cga
* Created: 19 Apr 2020 06:11:42 GMT
* Author: javii
version "2019.1"
attr Goal_Width = 6
attr Goal_Depth = 2
attr Number_Balls = 1
goalEdgeID =
else :
UV_Rotation =
else :
90
@StartRule
SoccerField -->
Goals
Balls
projectUV(0)
Field.
Goals -->
PutGoal(goalEdgeID)
GoalStripe -->
center(x)
i(goalAsset)
Goal.
Balls -->
PutBall -->
t(0,'0.5,0)
Ball.
