how to override block subdivision type
3775
04-05-2015 06:36 AM
miraybasyildirim
New Contributor II
I need to customize one of the methods for Block Subdivision (skeleton, recursive or offset subdivison).
To be precise I want to add lotDepth attribute in Block parameters.
Is that possible? And if It requires overriding the algorithm, is there any chance to see the source codes and edit them?
Thanks.
ChrisWilkins
see attached rule.
ChrisWilkins
You can turn off subdivision by setting shape creation to false on the block, then write a CGA rule that subdivides in the way you need, and then convert the model generated by the rule to shapes, and run rules on those shapes.
miraybasyildirim
New Contributor II
Thank for your reply.
Can you suggest any source that could help me  to write sudivision rules.
ChrisWilkins
see attached rule.
miraybasyildirim
New Contributor II
Dear Chris,
It has been very helpful. Thank you very much
