HOW TO export CityEngine model to sketchup and lumion?
11800
10
12-16-2013 12:36 PM
MilosMandic
I'm having trouble importing my CityEngine model into sketchup.
Can anyone show me correct export parameters for sketchup? When I try to import .kml I get no results, and when I try to import .dae sketchup just stops working. I don't know what the problem is.
Also I'm trying to do the same thing with Lumion, so if anyone knows how, I would be grateful.
I want my material and textures to be kept after import.
Thanks in advance!
Milos
MatthiasBuehler1
to export to Blender, you MUST center the model ( use the model offset button in the obj exporter ).
I'm not sure why Blender does not import the textures. So please check if the mtl files are correctly created together with the obj files.
let me know ..
matt
ps. use CityEngine's Navigator Preview to check if the obj files are valid after export ! ( refresh the export directory to see the files after export )
