  To be honest,I have used both of them and tested many settings of them. I find that if the shapes are flat,it works very well.However,the shapes and the terrain don't fit well each other on the contrary.
  For example,there is a hill. Firstly, I use align shapes to terrain and align terrain to shapes next. Then I find only vertices around the shape get the elevation but the middle of the shape can't get the elevation from terrain and it likes a interpolation between the vertices.Finally,the hill becomes flat.What's more,align terrain to shapes doesn't work well if the shapes aren't flat such as lower terrain.
  Is there anything wrong and if there are better parameter combinations?
thanks
[ATTACH=CONFIG]26953[/ATTACH]  [ATTACH=CONFIG]26954[/ATTACH]  [ATTACH=CONFIG]26955[/ATTACH]  [ATTACH=CONFIG]26956[/ATTACH]
