Hello I am trying to get trees into City Engine using the Tutorial example from the ArcGIS Desktop 3D page: http://desktop.arcgis.com/en/3d/3d-cities/3d-city-base-layers/add-trees.htm. ?
6541
6
05-04-2016 02:15 PM
MarkSteger
New Contributor III
Tutorial example from the ArcGIS Desktop 3D page:  http://desktop.arcgis.com/en/3d/3d-cities/3d-city-base-layers/add-trees.htm.I am using the same schema that was used in the Portland example from the tutorial
and the 3DCIM plants rule package.
However, when I bring the feature class into City Engine and apply the
rule package and hit the Generate button, it creates a box out of the tree and
has a note on the box which states “Unknown Asset”.  Has this happened to anyone else?
DanPatterson_Retired
did you complete all the steps in the tutorial or just skip to the city engine part?
....The 3D tree models are scaled based on the native units (feet versus meters), combined with the height and diameter (if available) attributes calculated earlier in this workflow. The....
MarkSteger
New Contributor III
Hello and thanks for the reply, as I did work through the tutorial from the beginning to the end, and I have the same coordinate system for the feature class and as well as the same one in the City Engine scene, and the height and diameter calculated from the local DTM and nDTM, using the tools that were part of the tutorial.  The only issue I have had is getting the "Attribute Assistant" add-in that comes with the tutorial to work, but I am not sure this would cause the problem once in City Engine?
MicahTaylor
Occasional Contributor III
If you are using the data from the portland example (www.arcgis.com/home/item.html?id=44fc826520574946a97bf45ce0b7dffe) or you are using the example scene ("Portalnd 3D City.cej") then your trees should appear.  Try changing the subtype or type field.
However, if you are using your own tree points for the tutorial, then you need to make sure you followed all the previous steps as Dan mentioned.  The reason is...
The 3DCIM_Plants.rpk is looking for the "tree genus" in the attributes of the tree data (also looking for height, diameter, etc).  If that field is not present, spelled incorrectly, etc...then the asset cant be found and CE will give you a box.  However if you manually type in the subtype and type ...regenerate...then the trees SHOULD still appear.  However, this defeats the purpose of having a tree database with all the attributes in it so I would suggest going back in the lesson.
One disadvantage here appears to be that the 3DCIM uses rule packages as opposed to rules.  There is no way to edit the rule to check for file path errors.  I think (not 100% sure) all of your tree models are packaged up with the rule package...meaning you cannot move them.
Good luck. let me know how it goes.
MarkSteger
New Contributor III
Thanks Micah for the quick reply, as I do have the genus spelled correctly
and height and diameter, but maybe I am doing something wrong on the
CitiEngine side of things, oh well I am going to keep trying and I may have
a few more questions for you.
Thanks again,
LR
*.rpk files are just renamed *.7z archives - you can open them with 7zip. If you're lucky you'll find a cga file, unless whoever made the rpk didn't include it (cgb = compiled cga).
JustinConnerWR
/**Try this, assuming you have folders such as C:\Users\<username>\Documents\CityEngine\Default Workspace\ESRI.lib\assets\Plants\Norway_Spruce.  If you've added tree species, make sure they have aliases set up.
 * File:    Esri Vegetation Library with LumentRT 3D Plants - Plant Loader.cga
 * Created: 7 Nov 2013 19:16:08 GMT
 * Author:  Esri R&D Center Zurich
 * Modified 5/30/2018 by A.M.
version "2018.0"
# Control Attributes (set by user or geodatabase)
@Order(1) @Range("Alder Buckthorn","Algarrobo","Amazon Sword Plant","American Chestnut","American Elderberry","American Pepper","American Silverberry","Apricot","Ash","Ash, Green","Ash, White","Athel Tamarisk","Australian Pine","Avocado","Baldcypress","Bamboo","Banana Tree","Basswood","Bay Laurel","Birch, River","Black Tupelo","Blue Gum Eucalyptus","Boxwood","Buckthorn","Buttonbush","Cabbage Palm Fern","California Bay","California Incense Cedar","California Palm","California Redwood","Canada Buffaloberry","Cedar, Red","Chinaberry Tree","Chinese Tallow Tree","Coconut Palm","Common Hackberry","Common Holly","Common Persimmon","Common Whitebeam","Conker Tree","Cottonwood","Crabapple","Date Palm","Desert Bitterbrush","Desert Willow","Dogwood","Douglas Fir","Elm","Elm, Siberian","European Beech","European Hornbeam","European Larch","Ficus","Fir, Balsam","Flannelbush","Generic Dead Tree","Generic Stump","Generic Unknown","Giant Chinquapin","Giant Sequoia","Hawthorn","Hedgehog Agave","Honey Locust","Honeylocust","Hophornbeam","Huckleberry Shrub","Japanese Angelica Tree","Japanese Hemlock","Japanese Nutmeg","Judas Tree","Lacy Tree Philodendron","Lawson Cypress","Leyland Cypress","Lily of the Valley","Loblolly Bay","Locust, Black","Lodgepole Pine","Maple, Amur","Maple, Autumn Blaze","Maple, Norway","Maple, Red","Maple, Silver","Maple, Sugar","Mexican Buckeye","Mexican Palmetto","Mountain Mahogany","Mulberry","Necklacepod","Northern Bilberry","Northern Red Oak","Northern White Cedar","Oak, Black","Oak, Bur","Oak, White","Octopus Tree","Orchid","Osage Orange","Oval-leaved Privet","Palm Lily","Palo Verde","Paper Bark Tree","Paper Birch","Parlour Palm","Pawpaw","Persian Silk Tree","Pine, Eastern White","Pine, Red","Pine, Scotch","Planting Site, Small","Planting Site, Medium","Planting Site, Large","Poplar","Prickly Pear Cactus","Princess Tree","Red Alder","Red Hickory","Rhododendron Azaleas","Rose","Ruffle Palm","Saguaro Cactus","Sassafras","Sea Islands Yucca","Shadbush","Smooth Sumac","Snake Plant","Sourwood","Southern Magnolia","Southern Wax Myrtle","Spanish Broom","Spruce","Spruce, Colorado Blue","Spruce, Norway","Strawberry Tree","Stump","Sunflower","Sweetgum","Sycamore","Tanoak","Tree of Heaven","Turkish Hazel","Umbrella Acacia","Walnut, Black","Western Juniper","Western Soapberry","White Poplar","White Willow","Witch Hazel","Yellow Poplar","Yew")
attr Name                 = "Orange Tree"
@Order(2) @Range(0.5,80)
attr Height             = getStandardHeight                    # default depends on Name (i.e. adapts if user selects another plant (if not overwritten by user))
@Order(3) @Range(0.5,30)
attr Radius             = getRadius                         # default depends on Name and Height (and adapts in case user adjusts only height in Inspector)
@Group("Options",4) @Order(1) @Range("Model","Fan","Analytical")
attr Representation        = "Model"
@Group("Options") @Order(2) @Range(0,1)
attr Transparency         = 0
@Group("Options") @Order(3) @Color
attr OverwriteColor     = ""
@Group("Options") @Order(4)
attr RandomRotation     = true
@Group("Options") @Order(5) @Description("Note that this tripples the instance count e.g. web scenes get three times bigger")
attr RandomBrightness     = false
@Group("Options") @Order(5) @Range("Mature only","Mature and young")
attr RandomHeights         = "Mature and young"
@Group("Options") @Order(6) @Range("None","Metadata","Instance Information") @Description("Instance Information suited for LumentRT of e-on Software and other 3rd party applications.")
attr Reporting            = "None"
# Constants
const AssetFolder                    = "/ESRI.lib/assets/Plants"                         # no "/" at the end (taken care of below)
const FallbackPlant                    = "Generic Unknown"                                    # this plant representation is used in case the user-selected plant does not exist in library
const RandomRadiusDeviation            = 0.10                                                # plant radius varies plus/minus within this percentage
const RandomHeightYoungPercentage    = case RandomHeights=="Mature only": 0 else: 0.33     # this percentage gives random heights below the minheight
# Library Functions (suited for external usage)
# attribute lookups
getGenus(commonName)                = _genus(_indexFromCommonName(commonName))
getSpecies(commonName)                = _species(_indexFromCommonName(commonName))
getWikipediaURL(commonName)            = _wikipediaURL(_indexFromCommonName(commonName))                # consists of latin name
getStandardHeight(commonName)        = _heightAvg(_indexFromCommonName(commonName))
getMinimumHeight(commonName)        = _heightMin(_indexFromCommonName(commonName))
getMaximumHeight(commonName)        = _heightMax(_indexFromCommonName(commonName))
getRandomHeight(commonName)            = _randomHeight(_indexFromCommonName(commonName))
getStandardRadius(commonName)        = _radiusAvg(_indexFromCommonName(commonName))
getStandardTrunkRadius(commonName)    = _trunkRadiusAvg(_indexFromCommonName(commonName))
getStandardTrunkHeight(commonName)    = _trunkHeightAvg(_indexFromCommonName(commonName))
getRegions(commonName)                = _regions(_indexFromCommonName(commonName))
getCrownShape(commonName)            = _crownShape(_indexFromCommonName(commonName))
isProxy(commonName)                    = _proxy(_indexFromCommonName(commonName)) != "X"
# attribute lookups assuming that Name attr has been set correctly set
getGenus            = _genus(_indexFromCommonName(Name))
getSpecies            = _species(_indexFromCommonName(Name))
getWikipediaURL        = _wikipediaURL(_indexFromCommonName(Name))                # consists of latin name
getStandardHeight    = _heightAvg(_indexFromCommonName(Name))
getMinimumHeight    = _heightMin(_indexFromCommonName(Name))
getMaximumHeight    = _heightMax(_indexFromCommonName(Name))
getRandomHeight        = _randomHeight(_indexFromCommonName(Name))
getStandardRadius    = _radiusAvg(_indexFromCommonName(Name))
getRegions            = _regions(_indexFromCommonName(Name))
getHardinessZoneMin    = _zoneMin(_indexFromCommonName(Name))
getHardinessZoneMax    = _zoneMax(_indexFromCommonName(Name))
getCrownShape        = _crownShape(_indexFromCommonName(Name))
isProxy                = _proxy(_indexFromCommonName(Name)) != "X"
# attribute lookups assuming that Name and Height have been set
getRadius            = _radius(_indexFromCommonName(Name),Height)            # relative to current height
getRandomRadius        = _randomRadius(_indexFromCommonName(Name),Height)        # +-5% of default radius
getTrunkHeight        = _trunkHeight(_indexFromCommonName(Name),Height)        # relative to current height
# attribute lookups assuming that Name and Radius have been set
getTrunkRadius        = _trunkRadius(_indexFromCommonName(Name),Radius)        # relative to current radius
# general utility functions
isPlantInLibrary(commonName)    = listIndex(_dataCommonName,commonName) >= 0
## utility functions needed for setups which are driven by latin names (i.e. genus and species)
#isPlantInLibrary(genus,species) = listIndex(_dataLatinName,genus+" "+species) >= 0
#isGenusInLibrary(genus)            = listIndex(_dataGenus,genus) >= 0
#getCommonName(genus,species)    = _commonName(_indexFromLatinName(genus,species))    # NOTE: in case species is not given or wrong, then it falls back to first plant entry with this genus (i.e. first entry should be a very common species of this genus)
# Library data with accessors (for internal usage only)
# number of plants in library
const nPlants     = 149
const nModels    = 82    # models (= non-proxies) MUST be listed first in the data (see _getAsset function)
# THE data from Excel sheet (latin name contains both the genus AND species column)
#const _dataCommonName         = "Orange Tree;Balsam Fir;Umbrella Acacia;Maple, Norway;Maple, Sugar;Conker Tree;Hedgehog Agave;Ruffle Palm;Red Alder;Shadbush;Japanese Angelica Tree;Strawberry Tree;Paper Birch;Orchid;Boxwood;California Incense Cedar;Saguaro Cactus;Red Hickory;American Chestnut;Australian Pine;Mountain Mahogany;Parlour Palm;Desert Willow;Coconut Palm;Lily of the Valley;Palm Lily;Flowering Dogwood;Common Hawthorn;Leyland Cypress;Amazon Sword Plant;Blue Gum Eucalyptus;European Beech;Ficus;Alder Buckthorn;Ash, White;Flannelbush;Generic Stump;Generic Dead Tree;Generic Unknown;Witch Hazel;Sunflower;California Walnut;Western Juniper;European Larch;Bay Laurel;Oval-leaved Privet;Sweetgum;Southern Magnolia;Banana Tree;Prickly Pear Cactus;Palo Verde;Lacy Tree Philodendron;Cabbage Palm Fern;Date Palm;Bamboo;Norway Spruce;Lodgepole Pine;Scots Pine;American Sycamore;Poplar, White;Apricot;Douglas Fir;Northern Red Oak;Oak, White;Mediterranean Buckthorn;Rhododendron Azaleas;Black Locust;Rose;Mexican Palmetto;White Willow;Snake Plant;Sassafras;California Redwood;Giant Sequoia;Common Whitebeam;Spanish Broom;Baldcypress;Basswood;Field Elm;California Bay;California Palm;Sea Islands Yucca;Tree of Heaven;Persian Silk Tree;Pawpaw;European Hornbeam;Common Hackberry;Buttonbush;Judas Tree;Lawson Cypress;Giant Chinquapin;Turkish Hazel;Huckleberry Shrub;Common Persimmon;American Silverberry;Honey Locust;Loblolly Bay;Common Holly;Yellow Poplar;Tanoak;Osage Orange;Paper Bark Tree;Chinaberry Tree;White Mulberry;Southern Wax Myrtle;Black Tupelo;Hophornbeam;Sourwood;Princess Tree;Avocado;Algarrobo;Desert Bitterbrush;Smooth Sumac;American Elderberry;Western Soapberry;Octopus Tree;American Pepper;Canada Buffaloberry;Necklacepod;Athel Tamarisk;Yew;Northern White Cedar;Japanese Nutmeg;Chinese Tallow Tree;Japanese Hemlock;Mexican Buckeye;Northern Bilberry;"
#const _dataLatinName         = "Citrus Sinensis;Abies Balsamea;Acacia Tortilis;Acer Platanoides;Acer Saccharum;Aesculus Hippocastanum;Agave Stricta;Aiphanes Horrida;Alnus Rubra;Amelanchier Canadensis;Aralia Elata;Arbutus Unedo;Betula Papyrifera;Bulbophyllum Phalaenopsis;Buxus Sempervirens;Calocedrus Decurrens;Carnegiea Saguaro;Carya Ovalis;Castanea Dentata;Casuarina Equisetifolia;Cercocarpus Montanus;Chamaedorea Elegans;Chilopsis Linearis;Cocos Nucifera;Convallaria Majalis;Cordyline Petiolaris;Cornus Florida;Crataegus Monogyna;Cupressus Leylandii;Echinodorus Bleheri;Eucalyptus Globulus;Fagus Sylvatica;Ficus Benjamina;Frangula Alnus;Fraxinus Americana;Fremontodendron Californicum;Generic Stump;Generic DeadTree;Generic Unknown;Hamamelis Virginiana;Helianthus Annuus;Juglans Regia;Juniperus Occidentalis;Larix Decidua;Laurus Nobilis;Ligustrum Ovalifolium;Liquidambar Styraciflua;Magnolia Grandiflora;Musa Acuminata;Opuntia Aciculata;Parkinsonia Aculeata;Philodendron Selloum;Phlebodium Aureum;Phoenix Dactylifera;Phyllostachys Aurea;Picea Abies;Pinus Contorta;Pinus Sylvestris;Platanus Occidentalis;Populus Tremuloides;Prunus Armeniaca;Pseudotsuga Menziesii;Quercus Rubra;Quercus Alba;Rhamnus Alaternus;Rhododendron Tsutsuji;Robinia Pseudoacacia;Rosa Grandiflora;Sabal Mexicana;Salix Alba;Sansevieria Trifasciata;Sassafras Albidum;Sequoia Sempervirens;Sequoiadendron Giganteum;Sorbus Aria;Spartium Junceum;Taxodium Distichum;Tilia Americana;Ulmus Minor;Umbellularia Californica;Washingtonia Filifera;Yucca Gloriosa;Ailanthus Altissima;Albizia Julibrissin;Asimina Triloba;Carpinus Betulus;Celtis Occidentalis;Cephalanthus Occidentalis;Cercis Siliquastrum;Chamaecyparis Lawsoniana;Chrysolepis Chrysophylla;Corylus Colurna;Cyrilla Racemiflora;Diospyros Virginiana;Elaeagnus Commutata;Gleditsia Triacanthos;Gordonia Lasianthus;Ilex Aquifolium;Liriodendron Tulipifera;Lithocarpus Densiflorus;Maclura Pomifera;Melaleuca Quinquenervia;Melia Azedarach;Morus Alba;Myrica Cerifera;Nyssa Sylvatica;Ostrya Virginiana;Oxydendrum Arboreum;Paulownia Tomentosa;Persea Americana;Prosopis Nigra;Purshia Glandulosa;Rhus Glabra;Sambucus Canadensis;Sapindus Saponaria;Schefflera Actinophylla;Schinus Molle;Shepherdia Canadensis;Sophora Tomentosa;Tamarix Aphylla;Taxus Baccata;Thuja Occidentalis;Torreya Nucifera;Triadica Sebifera;Tsuga Diversifolia;Ungnadia Speciosa;Vaccinium Uliginosum;"
#const _dataGenus             = "Citrus;Abies;Acacia;Acer;Acer;Aesculus;Agave;Aiphanes;Alnus;Amelanchier;Aralia;Arbutus;Betula;Bulbophyllum;Buxus;Calocedrus;Carnegiea;Carya;Castanea;Casuarina;Cercocarpus;Chamaedorea;Chilopsis;Cocos;Convallaria;Cordyline;Cornus;Crataegus;Cupressus;Echinodorus;Eucalyptus;Fagus;Ficus;Frangula;Fraxinus;Fremontodendron;Generic;Generic;Generic;Hamamelis;Helianthus;Juglans;Juniperus;Larix;Laurus;Ligustrum;Liquidambar;Magnolia;Musa;Opuntia;Parkinsonia;Philodendron;Phlebodium;Phoenix;Phyllostachys;Picea;Pinus;Pinus;Platanus;Populus;Prunus;Pseudotsuga;Quercus;Quercus;Rhamnus;Rhododendron;Robinia;Rosa;Sabal;Salix;Sansevieria;Sassafras;Sequoia;Sequoiadendron;Sorbus;Spartium;Taxodium;Tilia;Ulmus;Umbellularia;Washingtonia;Yucca;Ailanthus;Albizia;Asimina;Carpinus;Celtis;Cephalanthus;Cercis;Chamaecyparis;Chrysolepis;Corylus;Cyrilla;Diospyros;Elaeagnus;Gleditsia;Gordonia;Ilex;Liriodendron;Lithocarpus;Maclura;Melaleuca;Melia;Morus;Myrica;Nyssa;Ostrya;Oxydendrum;Paulownia;Persea;Prosopis;Purshia;Rhus;Sambucus;Sapindus;Schefflera;Schinus;Shepherdia;Sophora;Tamarix;Taxus;Thuja;Torreya;Triadica;Tsuga;Ungnadia;Vaccinium;"
#const _dataSpecies             = "Sinensis;Balsamea;Tortilis;Platanoides;Saccharum;Hippocastanum;Stricta;Horrida;Rubra;Canadensis;Elata;Unedo;Papyrifera;Phalaenopsis;Sempervirens;Decurrens;Saguaro;Ovalis;Dentata;Equisetifolia;Montanus;Elegans;Linearis;Nucifera;Majalis;Petiolaris;Florida;Monogyna;Leylandii;Bleheri;Globulus;Sylvatica;Benjamina;Alnus;Americana;Californicum;Stump;DeadTree;Unknown;Virginiana;Annuus;Regia;Occidentalis;Decidua;Nobilis;Ovalifolium;Styraciflua;Grandiflora;Acuminata;Aciculata;Aculeata;Selloum;Aureum;Dactylifera;Aurea;Abies;Contorta;Sylvestris;Occidentalis;Tremuloides;Armeniaca;Menziesii;Rubra;Alba;Alaternus;Tsutsuji;Pseudoacacia;Grandiflora;Mexicana;Alba;Trifasciata;Albidum;Sempervirens;Giganteum;Aria;Junceum;Distichum;Americana;Minor;Californica;Filifera;Gloriosa;Altissima;Julibrissin;Triloba;Betulus;Occidentalis;Occidentalis;Siliquastrum;Lawsoniana;Chrysophylla;Colurna;Racemiflora;Virginiana;Commutata;Triacanthos;Lasianthus;Aquifolium;Tulipifera;Densiflorus;Pomifera;Quinquenervia;Azedarach;Alba;Cerifera;Sylvatica;Virginiana;Arboreum;Tomentosa;Americana;Nigra;Glandulosa;Glabra;Canadensis;Saponaria;Actinophylla;Molle;Canadensis;Tomentosa;Aphylla;Baccata;Occidentalis;Nucifera;Sebifera;Diversifolia;Speciosa;Uliginosum;"
#const _dataHeightMin        = "5;10;5;20;25;25;1;3;15;3;3;5;12;0.5;0.8;20;3;20;20;10;3;1;2;20;0.15;2;5;5;3;0.5;20;10;2;6;10;2;0.4;5;5;2;1.5;15;20;20;2;2;10;15;3;0.5;2;0.5;0.5;20;5;12;30;25;20;12;4;45;18;14;1;0.5;10;0.5;12;12;0.5;9;50;50;15;2;25;25;20;20;14;2;10;5;8;15;7;2;6;20;20;15;3;2;1;20;10;10;18;20;3;10;4;10;3;20;14;10;10;10;10;1;1;2;2;3;10;1;1;12;10;10;10;8;15;2;0.5;"
#const _dataHeightMax         = "13;20;15;30;35;35;2;10;20;5;5;10;18;1.5;1.2;30;9;30;30;20;4;3;6;30;0.3;4;10;15;7;1.5;30;15;4;14;16;4;1;35;35;4;3.5;25;25;40;6;4;16;25;6;1;6;1.5;1.5;25;9;20;50;45;40;20;10;75;35;24;5;2;16;1.5;18;18;1;18;80;80;25;4;40;35;26;30;22;3;15;12;12;25;13;4;10;40;30;25;5;4;3;30;20;10;32;25;7;20;12;14;5;25;18;20;25;20;20;3;4;4;6;15;15;4;3;18;20;20;20;12;25;4;1.5;"
#const _dataHeightAvg         = "9;15;10;25;30;30;1.5;6.5;17.5;4;4;7.5;15;1;1;25;6;25;25;15;3.5;2;4;25;0.25;3;7.5;10;5;1;25;12.5;3;10;13;3;0.6;20;20;3;2.5;20;22.5;30;4;3;13;20;4.5;0.75;4;1;1;22.5;7;16;40;32;30;16;7;60;24;19;3;1.25;13;1;15;15;0.75;13.5;65;65;20;3;30;30;23;25;18;2.5;12.5;8.5;10;20;10;3;8;30;25;20;4;3;2;25;15;15;24;22.5;5;15;8;12;4;22;16;15;17;15;15;2;2;3;4;10;12;2.5;2;15;15;15;15;10;20;3;1;"
#const _dataRadiusAvg         = "2.5;3.35;4.35;6.3;10.21;9;1.06;2.16;2.97;0.92;1.84;2.54;3.75;0.47;0.44;4.35;0.82;9.02;4.38;3.28;1.38;0.83;2.11;5.12;0.07;0.7;2.4;3.07;0.64;0.56;7.1;4.5;0.9;3.63;2.8;0.66;0.5;5;5;1.72;0.56;9.06;11.03;4.57;0.8;0.5;2.85;7.64;1.5;0.49;2.16;0.7;0.85;6.56;1.66;3.02;6.59;5.96;6.06;2.9;2.02;12.28;10.35;8.56;1.07;0.37;3.49;0.57;3.59;4.17;0.13;2.94;9.42;13.93;6;0.99;8.56;6.85;7.81;9.38;3.24;0.68;2.69;2.72;3;4.36;2.18;0.66;2.88;6.57;11.26;4.56;1.58;0.87;0.4;8.51;4.6;2.72;9.17;8.11;1.44;4.26;2.15;4.33;2.29;4.74;6.11;4.03;7.65;4.33;6.47;1.14;0.66;0.92;2.16;2.68;3.98;0.83;1.41;6.47;1.91;1.91;2.84;3;3.78;0.99;0.22;"
#const _dataCrownShape         = "S4;S8;S5;S4;S4;S5;S6;S6;S7;S6;S5;S4;S4;S2;S6;S4;S2;S4;S5;S6;S6;S5;S5;S4;S5;S5;S5;S5;S3;S5;S4;S4;S4;S5;S5;S7;S1;S4;S4;S4;S6;S4;S4;S4;S5;S7;S5;S4;S4;S4;S5;S6;S5;S4;S6;S5;S4;S6;S4;S5;S4;S6;S5;S4;S4;S6;S4;S4;S4;S6;S6;S5;S5;S4;S4;S5;S6;S5;S4;S4;S4;S4;S5;S5;S4;S5;S5;S7;S4;S6;S4;S5;S6;S4;S7;S4;S5;S5;S4;S4;S4;S4;S4;S4;S4;S5;S4;S4;S4;S4;S5;S4;S5;S5;S5;S4;S6;S5;S6;S5;S3;S3;S5;S4;S5;S5;S7;"
#const _dataTrunkRadiusAvg     = "0.13;0.35;0.35;0.46;0.85;0.8;0.04;0.1;0.34;0.12;0.11;0.21;0.23;0.05;0.05;0.31;0.18;0.68;0.56;0.32;0.12;0.04;0.13;0.2;0.05;0.03;0.23;0.21;0.09;0.07;0.64;0.32;0.06;0.1;0.17;0.1;0.5;0.5;0.5;0.06;0.04;0.4;1.03;0.5;0.06;0.11;0.2;0.48;0.09;0.04;0.09;0.1;0.09;0.54;0.08;0.23;0.58;0.39;0.68;0.23;0.11;0.88;0.82;0.46;0.11;0.03;0.18;0.05;0.21;0.23;0.04;0.22;1.3;2.39;0.29;0.1;0.46;0.43;1.11;1.1;0.25;0.04;0.17;0.26;0.2;0.33;0.16;0.1;0.2;0.64;0.61;0.29;0.13;0.05;0.07;0.7;0.32;0.22;0.58;0.57;0.08;0.38;0.11;0.32;0.08;0.29;0.38;0.2;0.41;0.23;0.51;0.09;0.07;0.06;0.09;0.13;0.18;0.08;0.2;0.51;0.26;0.26;0.21;0.15;0.28;0.1;0.03;"
#const _dataTrunkHeightAvg     = "2.1;4;5.2;4.25;8.1;4.8;0;3.64;6.3;0;1;2.17;3.3;0;0;6;1.32;4;7.25;2.25;0;0;1.52;15.75;0;0.81;2.17;2.1;0.15;0.26;7;3;0.63;1.8;1.43;0;0.6;6;6;0.45;0;4.8;7.87;4.5;0;0;2.34;3.2;2.48;0.04;1.36;0;0;12.6;0;2.4;8.6;7.36;6.6;2.08;1.75;7.2;9.84;3.99;0.24;0;4.03;0;9.15;4.9;0;2.97;29.9;9.1;6.8;0;16.5;6.6;7.59;6.75;11.7;0.68;1.38;2.46;2.1;4.4;2.2;0;1.92;4.5;5.25;4.4;0;0.75;0;6.75;3.15;1.95;3.84;5.4;1.25;4.2;2.48;1.92;0.6;2.42;2.56;4.65;3.57;3.75;6.15;0;0;0.63;1.36;3.1;3.36;0;0;6.15;0.45;0.45;2.25;3.4;3;0;0;"
#const _dataRegions             = "NA,EU,AS,SA;NA;AF,AS;EU,AS;NA,EU;EU;NA;SA,NA;NA;NA;AS;AS;NA;AS;NA,EU;NA;NA;NA,EU;NA,EU,AS;AU;NA;NA;NA;NA,AS;NA,AS,EU;AU;NA,EU;EU,AS,AF;NA,EU;SA,NA;AU,AS,NA;EU;AU;AU,EU;EU,NA,AS;NA,EU;NA,AS,EU,AF,SA,AU;NA,AS,EU,AF,SA,AU;NA,AS,EU,AF,SA,AU;NA;NA,SA,EU;EU,NA;NA;EU,NA,AS;EU,NA;EU;NA;NA;AS,SA;NA;NA,AF;NA,AF,AU;NA,SA;AS,NA,SA;AS;EU;NA;EU,AS,NA;NA;NA;NA,EU,AS;NA;NA;NA;EU;NA,EU,AS;NA,EU;NA,EU;NA;NA,EU,AS;AS,SA;NA;NA;NA;EU;EU,AS,AF;NA;NA;EU,NA;NA;NA;NA;AS,NA;AS;NA;EU;NA;NA;EU,AS;NA;NA;AS;NA,SA;NA,EU;NA;AS,NA;NA,AS;EU,AF,AS;NA,AS;NA;NA,AS;AU;AU;NA;NA;NA;EU,NA;NA;AS;NA;SA;NA;NA;NA;NA;AU;SA;NA;AS,NA;AF,AU,AS;EU,AF,AS;NA;AS;AS,NA;AS,NA;NA;NA;"
#const _dataZoneMin            = "9;3;9;3;3;4;10;10;7;4;4;7;2;11;5;5;8;4;4;9;4;10;7;10;2;10;5;4;6;10;9;4;10;3;3;9;0;0;0;3;4;5;5;3;8;4;5;6;9;8;8;8;9;8;6;2;1;3;4;2;5;3;3;3;8;3;4;3;8;2;9;4;7;6;6;8;4;3;3;9;9;6;5;6;5;5;3;4;6;5;6;4;5;4;2;4;8;5;4;7;4;9;7;4;7;4;3;5;6;9;9;3;3;4;7;9;8;2;9;7;5;2;6;8;6;7;2;"
#const _dataZoneMax            = "11;5;11;7;8;7;11;11;8;7;8;9;7;11;8;8;11;8;8;11;4;11;11;11;7;11;9;8;10;11;11;7;11;7;9;11;12;12;12;8;9;9;8;6;10;7;9;10;11;10;11;11;11;11;11;7;7;7;9;5;7;6;8;9;9;7;9;10;11;8;11;8;10;8;8;9;10;9;9;11;11;11;8;9;8;7;9;10;9;7;9;7;10;9;6;8;9;9;9;11;9;11;9;9;10;9;9;8;9;10;9;9;9;9;10;11;11;6;11;10;8;8;10;10;9;9;6;"
#const _dataProxy             = "X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;Ash, White;Flowering Dogwood;Ficus;Sassafras;Sassafras;Flannelbush;European Beech;Australian Pine;Oak, White;Basswood;Mountain Mahogany;Apricot;Flannelbush;Maple, Sugar;Common Hawthorn;White Poplar;Southern Magnolia;European Beech;Apricot;Blue Gum Eucalyptus;Black Locust;Red Hickory;Witch Hazel;Ash, White;Southern Magnolia;Black Locust;Oak, White;Apricot;Northern Red Oak;Rose;Spanish Broom;Common Hawthorn;Palo Verde;Black Locust;White Willow;Spanish Broom;Lacy Tree Philodendron;Northern Red Oak;Leyland Cypress;Leyland Cypress;Norway Spruce;Common Whitebeam;Norway Spruce;Spanish Broom;Flannelbush;"
const _dataCommonName         = "Orange Tree;Fir, Balsam;Umbrella Acacia;Maple, Norway;Maple, Sugar;Maple, Silver;Maple, Red;Maple, Amur;Maple, Autumn Blaze;Crabapple;Conker Tree;Hedgehog Agave;Ruffle Palm;Red Alder;Shadbush;Japanese Angelica Tree;Strawberry Tree;Paper Birch;Birch, River;Orchid;Boxwood;California Incense Cedar;Saguaro Cactus;Red Hickory;American Chestnut;Australian Pine;Mountain Mahogany;Parlour Palm;Desert Willow;Coconut Palm;Lily of the Valley;Palm Lily;Dogwood;Hawthorn;Leyland Cypress;Amazon Sword Plant;Blue Gum Eucalyptus;European Beech;Ficus;Alder Buckthorn;Ash, White;Ash, Green;Ash;Flannelbush;Generic Stump;Generic Dead Tree;Generic Unknown;Witch Hazel;Sunflower;Walnut, Black;Western Juniper;European Larch;Bay Laurel;Oval-leaved Privet;Sweetgum;Southern Magnolia;Banana Tree;Prickly Pear Cactus;Palo Verde;Lacy Tree Philodendron;Cabbage Palm Fern;Date Palm;Bamboo;Spruce, Norway;Spruce;Spruce, Colorado Blue;Pine, Red;Pine, Eastern White;Lodgepole Pine;Pine, Scotch;Sycamore;Cottonwood;Poplar;White Poplar;Apricot;Douglas Fir;Northern Red Oak;Oak, White;Oak, Bur;Oak, Black;Buckthorn;Rhododendron Azaleas;Locust, Black;Honeylocust;Rose;Mexican Palmetto;White Willow;Snake Plant;Sassafras;California Redwood;Giant Sequoia;Common Whitebeam;Spanish Broom;Baldcypress;Basswood;Elm;Elm, Siberian;California Bay;California Palm;Sea Islands Yucca;Tree of Heaven;Persian Silk Tree;Pawpaw;European Hornbeam;Common Hackberry;Buttonbush;Judas Tree;Lawson Cypress;Giant Chinquapin;Turkish Hazel;Huckleberry Shrub;Common Persimmon;American Silverberry;Honey Locust;Loblolly Bay;Common Holly;Yellow Poplar;Tanoak;Osage Orange;Paper Bark Tree;Chinaberry Tree;Mulberry;Southern Wax Myrtle;Black Tupelo;Hophornbeam;Sourwood;Princess Tree;Avocado;Algarrobo;Desert Bitterbrush;Smooth Sumac;American Elderberry;Western Soapberry;Octopus Tree;American Pepper;Canada Buffaloberry;Necklacepod;Athel Tamarisk;Yew;Northern White Cedar;Cedar, Red;Japanese Nutmeg;Chinese Tallow Tree;Japanese Hemlock;Mexican Buckeye;Northern Bilberry;Stump"
const _dataLatinName         = "Citrus Sinensis;Abies Balsamea;Acacia Tortilis;Acer Platanoides;Acer Saccharum;X;X;X;X;X;Aesculus Hippocastanum;Agave Stricta;Aiphanes Horrida;Alnus Rubra;Amelanchier Canadensis;Aralia Elata;Arbutus Unedo;Betula Papyrifera;X;Bulbophyllum Phalaenopsis;Buxus Sempervirens;Calocedrus Decurrens;Carnegiea Saguaro;Carya Ovalis;Castanea Dentata;Casuarina Equisetifolia;Cercocarpus Montanus;Chamaedorea Elegans;Chilopsis Linearis;Cocos Nucifera;Convallaria Majalis;Cordyline Petiolaris;Cornus Florida;Crataegus Monogyna;Cupressus Leylandii;Echinodorus Bleheri;Eucalyptus Globulus;Fagus Sylvatica;Ficus Benjamina;Frangula Alnus;Fraxinus Americana;X;X;Fremontodendron Californicum;Generic Stump;Generic DeadTree;Generic Unknown;Hamamelis Virginiana;Helianthus Annuus;X;Juniperus Occidentalis;Larix Decidua;Laurus Nobilis;Ligustrum Ovalifolium;Liquidambar Styraciflua;Magnolia Grandiflora;Musa Acuminata;Opuntia Aciculata;Parkinsonia Aculeata;Philodendron Selloum;Phlebodium Aureum;Phoenix Dactylifera;Phyllostachys Aurea;Picea Abies;X;X;X;X;Pinus Contorta;Pinus Sylvestris;Platanus Occidentalis;X;X;Populus Tremuloides;Prunus Armeniaca;Pseudotsuga Menziesii;Quercus Rubra;Quercus Alba;X;X;Rhamnus Alaternus;Rhododendron Tsutsuji;Robinia Pseudoacacia;X;Rosa Grandiflora;Sabal Mexicana;Salix Alba;Sansevieria Trifasciata;Sassafras Albidum;Sequoia Sempervirens;Sequoiadendron Giganteum;Sorbus Aria;Spartium Junceum;Taxodium Distichum;Tilia Americana;Ulmus Minor;X;Umbellularia Californica;Washingtonia Filifera;Yucca Gloriosa;Ailanthus Altissima;Albizia Julibrissin;Asimina Triloba;Carpinus Betulus;Celtis Occidentalis;Cephalanthus Occidentalis;Cercis Siliquastrum;Chamaecyparis Lawsoniana;Chrysolepis Chrysophylla;Corylus Colurna;Cyrilla Racemiflora;Diospyros Virginiana;Elaeagnus Commutata;Gleditsia Triacanthos;Gordonia Lasianthus;Ilex Aquifolium;Liriodendron Tulipifera;Lithocarpus Densiflorus;Maclura Pomifera;Melaleuca Quinquenervia;Melia Azedarach;X;Myrica Cerifera;Nyssa Sylvatica;Ostrya Virginiana;Oxydendrum Arboreum;Paulownia Tomentosa;Persea Americana;Prosopis Nigra;Purshia Glandulosa;Rhus Glabra;Sambucus Canadensis;Sapindus Saponaria;Schefflera Actinophylla;Schinus Molle;Shepherdia Canadensis;Sophora Tomentosa;Tamarix Aphylla;Taxus Baccata;Thuja Occidentalis;X;Torreya Nucifera;Triadica Sebifera;Tsuga Diversifolia;Ungnadia Speciosa;Vaccinium Uliginosum;Stump;Planting Site, Small; Planting Site, Medium; Planting Site, Large"
const _dataGenus             = "Citrus;Abies;Acacia;Acer;Acer;Acer;Acer;Acer;Acer;X;Aesculus;Agave;Aiphanes;Alnus;Amelanchier;Aralia;Arbutus;Betula;Betula;Bulbophyllum;Buxus;Calocedrus;Carnegiea;Carya;Castanea;Casuarina;Cercocarpus;Chamaedorea;Chilopsis;Cocos;Convallaria;Cordyline;Cornus;Crataegus;Cupressus;Echinodorus;Eucalyptus;Fagus;Ficus;Frangula;Fraxinus;Fraxinus;Fraxinus;Fremontodendron;Generic;Generic;Generic;Hamamelis;Helianthus;Juglans;Juniperus;Larix;Laurus;Ligustrum;Liquidambar;Magnolia;Musa;Opuntia;Parkinsonia;Philodendron;Phlebodium;Phoenix;Phyllostachys;Picea;Picea;Picea;Pinus;Pinus;Pinus;Pinus;Platanus;Populus;Populus;Populus;Prunus;Pseudotsuga;Quercus;Quercus;Quercus;Quercus;Rhamnus;Rhododendron;Robinia;Robinia;Rosa;Sabal;Salix;Sansevieria;Sassafras;Sequoia;Sequoiadendron;Sorbus;Spartium;Taxodium;Tilia;Ulmus;Ulmus;Umbellularia;Washingtonia;Yucca;Ailanthus;Albizia;Asimina;Carpinus;Celtis;Cephalanthus;Cercis;Chamaecyparis;Chrysolepis;Corylus;Cyrilla;Diospyros;Elaeagnus;Gleditsia;Gordonia;Ilex;Liriodendron;Lithocarpus;Maclura;Melaleuca;Melia;Morus;Myrica;Nyssa;Ostrya;Oxydendrum;Paulownia;Persea;Prosopis;Purshia;Rhus;Sambucus;Sapindus;Schefflera;Schinus;Shepherdia;Sophora;Tamarix;Taxus;Thuja;Thuja;Torreya;Triadica;Tsuga;Ungnadia;Vaccinium;Stump;Stump;Stump;Stump"
const _dataSpecies             = "Sinensis;Balsamea;Tortilis;Platanoides;Saccharum;X;X;X;X;X;Hippocastanum;Stricta;Horrida;Rubra;Canadensis;Elata;Unedo;Papyrifera;X;Phalaenopsis;Sempervirens;Decurrens;Saguaro;Ovalis;Dentata;Equisetifolia;Montanus;Elegans;Linearis;Nucifera;Majalis;Petiolaris;Florida;Monogyna;Leylandii;Bleheri;Globulus;Sylvatica;Benjamina;Alnus;Americana;X;X;Californicum;Stump;DeadTree;Unknown;Virginiana;Annuus;X;Occidentalis;Decidua;Nobilis;Ovalifolium;Styraciflua;Grandiflora;Acuminata;Aciculata;Aculeata;Selloum;Aureum;Dactylifera;Aurea;Abies;X;X;X;X;Contorta;Sylvestris;Occidentalis;X;X;Tremuloides;Armeniaca;Menziesii;Rubra;Alba;X;X;Alaternus;Tsutsuji;Pseudoacacia;X;Grandiflora;Mexicana;Alba;Trifasciata;Albidum;Sempervirens;Giganteum;Aria;Junceum;Distichum;Americana;Minor;X;Californica;Filifera;Gloriosa;Altissima;Julibrissin;Triloba;Betulus;Occidentalis;Occidentalis;Siliquastrum;Lawsoniana;Chrysophylla;Colurna;Racemiflora;Virginiana;Commutata;Triacanthos;Lasianthus;Aquifolium;Tulipifera;Densiflorus;Pomifera;Quinquenervia;Azedarach;X;Cerifera;Sylvatica;Virginiana;Arboreum;Tomentosa;Americana;Nigra;Glandulosa;Glabra;Canadensis;Saponaria;Actinophylla;Molle;Canadensis;Tomentosa;Aphylla;Baccata;Occidentalis;X;Nucifera;Sebifera;Diversifolia;Speciosa;Uliginosum;Stump;Stump;Stump;Stump"
const _dataHeightMin        = "5;10;5;20;25;25;25;25;25;5;25;1;3;15;3;3;5;12;12;0.5;0.8;20;3;20;20;10;3;1;2;20;0.15;2;5;5;3;0.5;20;10;2;6;10;10;10;2;0.4;5;5;2;1.5;15;20;20;2;2;10;15;3;0.5;2;0.5;0.5;20;5;12;12;12;30;30;30;25;20;12;12;12;4;45;18;14;14;14;1;0.5;10;10;0.5;12;12;0.5;9;50;50;15;2;25;25;20;20;20;14;2;10;5;8;15;7;2;6;20;20;15;3;2;1;20;10;10;18;20;3;10;4;10;3;20;14;10;10;10;10;1;1;2;2;3;10;1;1;12;10;10;10;10;8;15;2;0.5;0.4;0;0;0"
const _dataHeightMax         = "13;20;15;30;35;35;35;30;30;10;35;2;10;20;5;5;10;18;18;1.5;1.2;30;9;30;30;20;4;3;6;30;0.3;4;10;15;7;1.5;30;15;4;14;16;16;16;4;1;35;35;4;3.5;25;25;40;6;4;16;25;6;1;6;1.5;1.5;25;9;20;20;20;50;50;50;45;40;20;20;20;10;75;35;24;24;24;5;2;16;16;1.5;18;18;1;18;80;80;25;4;40;35;26;26;30;22;3;15;12;12;25;13;4;10;40;30;25;5;4;3;30;20;10;32;25;7;20;12;14;5;25;18;20;25;20;20;3;4;4;6;15;15;4;3;18;20;20;20;20;12;25;4;1.5;1;0;0;0"
const _dataHeightAvg         = "9;15;10;25;30;30;30;25;25;7.5;30;1.5;6.5;17.5;4;4;7.5;15;15;1;1;25;6;25;25;15;3.5;2;4;25;0.25;3;7.5;10;5;1;25;12.5;3;10;13;13;13;3;0.6;20;20;3;2.5;20;22.5;30;4;3;13;20;4.5;0.75;4;1;1;22.5;7;16;16;16;40;40;40;32;30;16;16;16;7;60;24;19;19;19;3;1.25;13;13;1;15;15;0.75;13.5;65;65;20;3;30;30;23;23;25;18;2.5;12.5;8.5;10;20;10;3;8;30;25;20;4;3;2;25;15;15;24;22.5;5;15;8;12;4;22;16;15;17;15;15;2;2;3;4;10;12;2.5;2;15;15;15;15;15;10;20;3;1;0.6;0;0;0"
const _dataRadiusAvg         = "2.5;3.35;4.35;6.3;10.21;10.21;10.21;10.21;10.21;2.4;9;1.06;2.16;2.97;0.92;1.84;2.54;3.75;3.75;0.47;0.44;4.35;0.82;9.02;4.38;3.28;1.38;0.83;2.11;5.12;0.07;0.7;2.4;3.07;0.64;0.56;7.1;4.5;0.9;3.63;2.8;2.8;2.8;0.66;0.5;5;5;1.72;0.56;9.06;11.03;4.57;0.8;0.5;2.85;7.64;1.5;0.49;2.16;0.7;0.85;6.56;1.66;3.02;3.02;3.02;6.59;6.59;6.59;5.96;6.06;2.9;2.9;2.9;2.02;12.28;10.35;8.56;10;9;1.07;0.37;3.49;3.49;0.57;3.59;4.17;0.13;2.94;9.42;13.93;6;0.99;8.56;6.85;7.81;7.81;9.38;3.24;0.68;2.69;2.72;3;4.36;2.18;0.66;2.88;6.57;11.26;4.56;1.58;0.87;0.4;8.51;4.6;2.72;9.17;8.11;1.44;4.26;2.15;4.33;2.29;4.74;6.11;4.03;7.65;4.33;6.47;1.14;0.66;0.92;2.16;2.68;3.98;0.83;1.41;6.47;1.91;1.91;1.91;2.84;3;3.78;0.99;0.22;0.5;0;0;0"
const _dataCrownShape         = "S4;S8;S5;S4;S4;S4;S4;S4;S4;S5;S5;S6;S6;S7;S6;S5;S4;S4;S4;S2;S6;S4;S2;S4;S5;S6;S6;S5;S5;S4;S5;S5;S5;S5;S3;S5;S4;S4;S4;S5;S5;S5;S5;S7;S1;S4;S4;S4;S6;S4;S4;S4;S5;S7;S5;S4;S4;S4;S5;S6;S5;S4;S6;S5;S5;S5;S4;S4;S4;S6;S4;S5;S5;S5;S4;S6;S5;S4;S4;S4;S4;S6;S4;S4;S4;S4;S6;S6;S5;S5;S4;S4;S5;S6;S5;S4;S4;S4;S4;S4;S5;S5;S4;S5;S5;S7;S4;S6;S4;S5;S6;S4;S7;S4;S5;S5;S4;S4;S4;S4;S4;S4;S4;S5;S4;S4;S4;S4;S5;S4;S5;S5;S5;S4;S6;S5;S6;S5;S3;S3;S3;S5;S4;S5;S5;S7;S1;S1;S1;S1"
const _dataTrunkRadiusAvg     = "0.13;0.35;0.35;0.46;0.85;0.85;0.85;0.85;0.85;0.23;0.8;0.04;0.1;0.34;0.12;0.11;0.21;0.23;0.23;0.05;0.05;0.31;0.18;0.68;0.56;0.32;0.12;0.04;0.13;0.2;0.05;0.03;0.23;0.21;0.09;0.07;0.64;0.32;0.06;0.1;0.17;0.17;0.17;0.1;0.5;0.5;0.5;0.06;0.04;0.4;1.03;0.5;0.06;0.11;0.2;0.48;0.09;0.04;0.09;0.1;0.09;0.54;0.08;0.23;0.23;0.23;0.58;0.58;0.58;0.39;0.68;0.23;0.23;0.23;0.11;0.88;0.82;0.46;0.46;0.46;0.11;0.03;0.18;0.18;0.05;0.21;0.23;0.04;0.22;1.3;2.39;0.29;0.1;0.46;0.43;1.11;1.11;1.1;0.25;0.04;0.17;0.26;0.2;0.33;0.16;0.1;0.2;0.64;0.61;0.29;0.13;0.05;0.07;0.7;0.32;0.22;0.58;0.57;0.08;0.38;0.11;0.32;0.08;0.29;0.38;0.2;0.41;0.23;0.51;0.09;0.07;0.06;0.09;0.13;0.18;0.08;0.2;0.51;0.26;0.26;0.26;0.21;0.15;0.28;0.1;0.03;0.5;0;0;0"
const _dataTrunkHeightAvg     = "2.1;4;5.2;4.25;8.1;8.1;8.1;8.1;8.1;2.17;4.8;0;3.64;6.3;0;1;2.17;3.3;3.3;0;0;6;1.32;4;7.25;2.25;0;0;1.52;15.75;0;0.81;2.17;2.1;0.15;0.26;7;3;0.63;1.8;1.43;1.43;1.43;0;0.6;6;6;0.45;0;4.8;7.87;4.5;0;0;2.34;3.2;2.48;0.04;1.36;0;0;12.6;0;2.4;2.4;2.4;8.6;8.6;8.6;7.36;6.6;2.08;2.08;2.08;1.75;7.2;9.84;3.99;3.99;3.99;0.24;0;4.03;4.03;0;9.15;4.9;0;2.97;29.9;9.1;6.8;0;16.5;6.6;7.59;7.59;6.75;11.7;0.68;1.38;2.46;2.1;4.4;2.2;0;1.92;4.5;5.25;4.4;0;0.75;0;6.75;3.15;1.95;3.84;5.4;1.25;4.2;2.48;1.92;0.6;2.42;2.56;4.65;3.57;3.75;6.15;0;0;0.63;1.36;3.1;3.36;0;0;6.15;0.45;0.45;0.45;2.25;3.4;3;0;0;0.6;0;0;0"
const _dataRegions             = "NA,EU,AS,SA;NA;AF,AS;EU,AS;NA,EU;NA,EU;NA,EU;NA,EU;NA,EU;NA,EU;EU;NA;SA,NA;NA;NA;AS;AS;NA;NA;AS;NA,EU;NA;NA;NA,EU;NA,EU,AS;AU;NA;NA;NA;NA,AS;NA,AS,EU;AU;NA,EU;EU,AS,AF;NA,EU;SA,NA;AU,AS,NA;EU;AU;AU,EU;EU,NA,AS;EU,NA,AS;EU,NA,AS;NA,EU;NA,AS,EU,AF,SA,AU;NA,AS,EU,AF,SA,AU;NA,AS,EU,AF,SA,AU;NA;NA,SA,EU;EU,NA;NA;EU,NA,AS;EU,NA;EU;NA;NA;AS,SA;NA;NA,AF;NA,AF,AU;NA,SA;AS,NA,SA;AS;EU;EU;EU;NA;NA;NA;EU,AS,NA;NA;NA;NA;NA;NA,EU,AS;NA;NA;NA;NA;NA;EU;NA,EU,AS;NA,EU;NA,EU;NA,EU;NA;NA,EU,AS;AS,SA;NA;NA;NA;EU;EU,AS,AF;NA;NA;EU,NA;EU,NA;NA;NA;NA;AS,NA;AS;NA;EU;NA;NA;EU,AS;NA;NA;AS;NA,SA;NA,EU;NA;AS,NA;NA,AS;EU,AF,AS;NA,AS;NA;NA,AS;AU;AU;NA;NA;NA;EU,NA;NA;AS;NA;SA;NA;NA;NA;NA;AU;SA;NA;AS,NA;AF,AU,AS;EU,AF,AS;NA;NA;AS;AS,NA;AS,NA;NA;NA;NA,AS,EU,AF,SA,AU;NA,AS,EU,AF,SA,AU;NA,AS,EU,AF,SA,AU;NA,AS,EU,AF,SA,AU"
const _dataZoneMin            = "9;3;9;3;3;3;3;3;3;5;4;10;10;7;4;4;7;2;2;11;5;5;8;4;4;9;4;10;7;10;2;10;5;4;6;10;9;4;10;3;3;3;3;9;0;0;0;3;4;5;5;3;8;4;5;6;9;8;8;8;9;8;6;2;2;2;1;1;1;3;4;2;2;2;5;3;3;3;3;3;8;3;4;4;3;8;2;9;4;7;6;6;8;4;3;3;3;9;9;6;5;6;5;5;3;4;6;5;6;4;5;4;2;4;8;5;4;7;4;9;7;4;7;4;3;5;6;9;9;3;3;4;7;9;8;2;9;7;5;2;2;6;8;6;7;2;0;0;0;0"
const _dataZoneMax            = "11;5;11;7;8;8;8;8;8;9;7;11;11;8;7;8;9;7;7;11;8;8;11;8;8;11;4;11;11;11;7;11;9;8;10;11;11;7;11;7;9;9;9;11;12;12;12;8;9;9;8;6;10;7;9;10;11;10;11;11;11;11;11;7;7;7;7;7;7;7;9;5;5;5;7;6;8;9;9;9;9;7;9;9;10;11;8;11;8;10;8;8;9;10;9;9;9;11;11;11;8;9;8;7;9;10;9;7;9;7;10;9;6;8;9;9;9;11;9;11;9;9;10;9;9;8;9;10;9;9;9;9;10;11;11;6;11;10;8;8;8;10;10;9;9;6;12;12;12;12"
const _dataProxy             = "X;Balsam Fir;X;Norway Maple;Sugar Maple;Norway Maple;Sugar Maple;Norway Maple;Norway Maple;Apricot;X;X;X;X;X;X;X;X;Paper Birch;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;X;White Ash;White Ash;White Ash;X;X;X;X;X;X;California Walnut;X;X;X;X;X;X;X;X;X;X;X;X;X;Norway Spruce;Norway Spruce;Norway Spruce;Scots Pine;Scots Pine;X;Scots Pine;American Sycamore;White Poplar;White Poplar;X;X;X;X;White Oak;White Oak;Northern Red Oak;X;X;Black Locust;Black Locust;X;X;X;X;X;X;X;X;X;X;X;Field Elm;Field Elm;X;X;X;White Ash;Flowering Dogwood;Ficus;Sassafras;Sassafras;Flannelbush;European Beech;Australian Pine;White Oak;Basswood;Mountain Mahogany;Apricot;Flannelbush;Sugar Maple;Common Hawthorn;White Poplar;Southern Magnolia;European Beech;Apricot;Blue Gum Eucalyptus;Black Locust;Red Hickory;Witch Hazel;White Ash;Southern Magnolia;Black Locust;White Oak;Apricot;Northern Red Oak;Rose;Spanish Broom;Common Hawthorn;Palo Verde;Black Locust;White Willow;Spanish Broom;Lacy Tree Philodendron;Northern Red Oak;Leyland Cypress;Leyland Cypress;Leyland Cypress;Norway Spruce;Common Whitebeam;Norway Spruce;Spanish Broom;Flannelbush;Generic Stump;Generic Stump;Generic Stump;Generic Stump"
# getting index for accessors either via common
_indexFromCommonName(commonName)     = _indexCheck(listIndex(_dataCommonName,commonName))
_indexCheck(idx)                    = case idx < 0: _fallbackIdx else: idx        # fallback if plant has not been found
# getting index via latin name: in case plant cannot be found, we try to search a plant of at least the given genus as first fallback
_indexFromLatinName(genus,species)    = _indexCheckLatin(listIndex(_dataLatinName,genus+" "+species),genus)
_indexCheckLatin(idx,genus)            = case idx < 0: _indexCheck(listIndex(_dataGenus,genus)) else: idx
# this plantNbr is displayed if the user-selected plant does not exist in library
#const _fallbackIdx    = listIndex(_dataCommonName,FallbackPlant)
const _fallbackIdx    = 4
# accessors
_commonName(idx)    = listItem(_dataCommonName,idx)
_latinName(idx)        = listItem(_dataLatinName,idx)
_genus(idx)            = listItem(_dataGenus,idx)
_species(idx)        = listItem(_dataSpecies,idx)
_heightMax(idx)        = float(listItem(_dataHeightMax,idx))
_heightMin(idx)        = float(listItem(_dataHeightMin,idx))
_heightAvg(idx)        = case _valid(idx): float(listItem(_dataHeightAvg,idx)) else: 1    # to avoid divisions by zero
_radiusAvg(idx)        = case _valid(idx): float(listItem(_dataRadiusAvg,idx)) else: 1    # to avoid divisions by zero
_trunkHeightAvg(idx)= float(listItem(_dataTrunkHeightAvg,idx))
_trunkRadiusAvg(idx)= float(listItem(_dataTrunkRadiusAvg,idx))
_crownShape(idx)    = listItem(_dataCrownShape,idx)
_regions(idx)        = listItem(_dataRegions,idx)
_zoneMin(idx)        = float(listItem(_dataZoneMin,idx))
_zoneMax(idx)        = float(listItem(_dataZoneMax,idx))
_proxy(idx)            = listItem(_dataProxy,idx)
# special accessors: randomHeight
_randomHeight(idx)     = case p(RandomHeightYoungPercentage): _randomHeightYoung(_heightMin(idx))
                      else                                  : _randomHeightMature(_heightMin(idx),_heightMax(idx))
_randomHeightYoung(hMin)        = rand(hMin/2,hMin)
_randomHeightMature(hMin,hMax)     = rand(hMin,hMax)
# special accessors: getting plant attributes for given height or radius
_radius(idx,height)            = _radiusAvg(idx) * height/_heightAvg(idx)
_randomRadius(idx,height)    = _radius(idx,height) * rand(1-RandomRadiusDeviation,1+RandomRadiusDeviation)
_trunkHeight(idx,height)    = _trunkHeightAvg(idx) * height/_heightAvg(idx)
_trunkRadius(idx,radius)    = _trunkRadiusAvg(idx) * radius/_trunkRadiusAvg(idx)
# helper
_valid(idx)                    = 0 <= idx && idx < nPlants
_wikipediaURL(idx)            = "http://en.wikipedia.org/wiki/" + _genus(idx) + "_" + _species(idx)
# Internal functions for rules only
# for higher performance (i.e. plant index for getting radius/height/radius can be stored to avoid multiple index lookups via name)
@Hidden
attr _plantNbr         = 0
@Hidden
attr _plantName     = ""
@Hidden
attr _plantHeight     = 0
@Hidden
attr _plantRadius     = 0
# validate name (assummes that _plantNbr has been set)
_validate(name)    = case _plantNbr==_fallbackIdx: FallbackPlant else: name
# file handling (assumes that Name and _plantNbr is correctly set)
_getAsset =
    case _plantNbr < nModels: _getFilepath(replace(_plantName," ","_"))
    else                    : _getFilepath(replace(_proxy(_plantNbr)," ","_"))
_getFilepath(commonNameUnderscores)    =
    case fileExists(AssetFolder + "/" + commonNameUnderscores + "/" + commonNameUnderscores + "_" + Representation + "_0.obj"):
    else:
        AssetFolder + "/Generic_Unknown/Generic_Unknown_" + Representation + "_0.obj"
# asset scale handling (assumes that Height, Radius, _plantNbr have been set and the asset has been inserted)
_getScaleY            = _plantHeight/scope.sy
_getScaleXZ            =
    case _plantRadius > 0 : _plantRadius/_radius(_plantNbr,scope.sy)                                            # the ratio of the user-set ratio versus the ratio of the inserted asset (since the ratio does not correspond to the bounding box, this has to be looked up (i.e. getting the value of the average-sized tree))
    else                  : _plantHeight/scope.sy * rand(1-RandomRadiusDeviation,1+RandomRadiusDeviation)        # in case the Radius is zero, we assume the (most typical) random case. This is for performance reasons only --> see also alternative plant loader rule which uses this as marker (to save above lookups which are not needed if the user-set Radius has not been set)
# rule helpers
_roundTransparency    = rint(20*Transparency) / 20            # round to 0.05 steps (to avoid the creation of too many materials)
_randomRotation     = case RandomRotation: rand(0,360) else: 0
###   RULES
# Plant Loader
@StartRule # assumes that all main attributes have been set outside
Generate -->
    case Height > 0:
        set(_plantNbr,_indexFromCommonName(Name))
        set(_plantName,_validate(Name))
        set(_plantHeight,Height)
        set(_plantRadius,Radius)
        s(0,0,0) center(xyz)
        alignScopeToAxes(y)
        TrunkOrigin
    else:
        Generate(Name)
TrunkOrigin -->
    case Representation == "Analytical":
        PlantAnalytical
    case Representation == "Fan":
        PlantFan
    else:
        PlantModel
# Alternative Plant Loader (doesn't use the main attributes!)
# In the most typical design use case where a random-sized plant needs to
# be set, we recommend to use this rule in the importing rule file.
# On the one hand it is more practical since the attributes do not need to be
# set before calling it as in the Plant rule above. But the main reason why
# we are provding this rule is that it is faster (because less library lookups
# are required here).
Generate(name) -->
    set(_plantNbr,_indexFromCommonName(name))
    set(_plantName,_validate(name))
    set(_plantHeight,_randomHeight(_plantNbr))
    set(_plantRadius,0)    # marks that the random radius can be used
    s(0,0,0) center(xyz) alignScopeToAxes(y)
    TrunkOrigin
# Realistic Model
PlantModel -->
    PlantModel(_getAsset)
PlantModel(asset) -->                            # needs special treatment because the bbox of the asset is not centered in orgin:
    i(asset)
    PlantModel(_getScaleY,_getScaleXZ,
               assetInfo(asset,tx)/scope.sx,    # relative origin offset in x-dir (trunk is at origin i.e. this value is needed for scaling around origin)
               assetInfo(asset,tz)/scope.sz)       # relative origin offset in z-dir (trunk is at origin i.e. this value is needed for scaling around origin)
PlantModel(scaleY,scaleXZ,relOffsetX,relOffsetZ) -->
    t('-relOffsetX,0,'-relOffsetZ)
    r(0,_randomRotation,0)
    s('scaleXZ,'scaleY,'scaleXZ)                # scale standard model to meet the user-given Height and Radius
    t('relOffsetX,0,'relOffsetZ)
    PlantVisualization
# Analytical Model
PlantAnalytical -->
    i(_getAsset)
    PlantAnalytical(_getScaleY,_getScaleXZ)
PlantAnalytical(scaleY,scaleXZ) -->
    s('scaleXZ,'scaleY,'scaleXZ) center(xz)
    PlantVisualization
# Fan
PlantFan -->
    i(_getAsset)
    PlantFan(_getScaleY,_getScaleXZ)
PlantFan(scaleY,scaleXZ) -->
    r(scopeCenter,0,_randomRotation,0)
    PlantVisualization
# Post operations
PlantVisualization -->
    case OverwriteColor != "" && _roundTransparency > 0.01:        # leaf cards will not work in webgl anymore (CE2013)
        set(material.opacity,1-_roundTransparency)
        set(material.colormap,"")
        color(OverwriteColor)
        PlantReporting
    case OverwriteColor != "":                                    # leaf cards will not work in webgl anymore (CE2013)
        PlantReporting
    case _roundTransparency > 0.01:                                # leaf cards will not work in webgl anymore (CE2013)
        PlantReporting
    case RandomBrightness:
        color(40%: "#ffffff" 33%: "#dddddd" else: "#bbbbbb")    # variation in brightness for better looks (but tripples the instance count...)
        PlantReporting
    else:
        PlantReporting
PlantReporting -->
    case Reporting == "Metadata":
        report( "Common Name",                 _plantName                                )
        report( "Genus",                     _genus(_plantNbr)                        )
        report( "Species",                     _species(_plantNbr)                        )
        report( "Total Height",             _plantHeight                            )
        report( "Trunk Height",             _trunkHeight(_plantNbr,_plantHeight)    )
        report( "Trunk Radius",             _trunkRadius(_plantNbr,_plantRadius)    )
        report( "Crown Radius",             _plantRadius                            )
        report( "Crown Shape",                 _crownShape(_plantNbr)                    )
        report( "Wikipedia URL for Species",_wikipediaURL(_plantNbr)                )
        report( "Minimun Height of Species",_heightMin(_plantNbr)                    )
        report( "Maximum Height of Species",_heightMax(_plantNbr)                    )
        report( "Hardiness Zone Min",         _zoneMin(_plantNbr)                        )
        report( "Hardiness Zone Max",         _zoneMax(_plantNbr)                        )
        report( "Contintents of Species",     _regions(_plantNbr)                        )
        PlantFinal.
    case Reporting == "Instance Information":
        PlantFinal.
        report("asset",                        "Plants/" + _plantName                    )
        report("scale",                     _plantHeight                            )
        # report position in world coords
        s(0.001,'1,0.001) center(xz)
        report("xpos",                         convert(x,scope,world,pos,0,0,0)        )
        report("ypos",                         convert(y,scope,world,pos,0,0,0)        )
        report("zpos",                         convert(z,scope,world,pos,0,0,0)        )
        # report rotation in world coords
        report("xrot",                         -(convert(x,scope,world,orient,0,0,0))    )
        report("yrot",                         -(convert(y,scope,world,orient,0,0,0))    )
        report("zrot",                         convert(z,scope,world,orient,0,0,0)        )
    else:
        PlantFinal.
