Has anybody tried integrating CityEngine with LumenRT?
905
07-15-2014 09:01 PM
IanThomas1
Hi All,
Great if you could share experiences, tricks and any cool output animations.
Thanks in advance,
Ian
DavidBurdick
Hi, Dave Burdick from e-on software here - the maker of LumenRT.  LumenRT works with CE 2012 thru 2014 using the LumenRT GeoDesign plugin.  You can learn more about LumenRT and the GeoDesign plugin here:
http://www.lumenrt.com/showcase/GeoDesign/http://www.lumenrt.com/showcase/GeoDesign/
ElliotHartley
LumenRT is great, my advice? start with small scenes and experiment, standard render is often 'good enough'.  If you were at the UC you would have seen the upcoming release which will blow you away with it's functionality!
stefanstamenov
LumenRT - Home
Is this LumenRT?
IanThomas1
Yep....LumenRT - Home‌ is the home of LumenRT
