greater than or less than
401
05-01-2014 05:21 AM
LukeCzar
Good morning,
I would like to use a Rule in which I use different color diagrams base on numbers, so If "something is greater than or less than"
How can I write that code?
For example:
[ATTACH=CONFIG]33525[/ATTACH]
Student hours:
219-1000    red color
1000-2000   yellow color
2000-4000   blue color
Lukasz
LukeCzar
I have a code:
case  StudentHours > 219  && StudentHours <1000   :
  set(material.color.a,0.8)color("#FF0000")
  extrude(StudentHours/160)
and it works,
what if I want to show different attributes in diagram? See attachment
Lukasz
MatthiasBuehler1
Frequent Contributor II
hi !
use functions instead, don't write that logic directly in the rules..
e.g.
getColor(value) =
    case value > 2000:
        ""#FF0000""
    case value > 1000:
        "#FF00FF"
    else:
        "#0000FF"
note that this works the same. I used different hex colors here though.
note that if the first case is not true, it goes to the next case, and so on,.. then returns the value.
