Generate reports from view analysis layers
528
07-17-2018 04:52 PM
KerryKang1
New Contributor II
Hello,
I am trying to generate a report from a viewdome analysis result (values in Visibility by Layer). Is it currently possible to extract this information in report?
I tried to apply report rule in cga, but was not able to apply it in this analysis layer.
CherylLau
No, sorry, it is not possible to report viewdome information.
KerryKang1
New Contributor II
Hello Cheryl,
Thank you for your response. so I assume that it is the same for other analysis layers -  no report available for view corridor and veiwshed. However, is there anyway to export that result into external files directly such as csv?
Thank you.
ThomasFuchs
Hi Kerry
There is 2 ways to do this:
  1. In the Inspector highlight the table with the visibility information, then copy paste into a spreadsheet
  2. Use Python to query the information and write it out to a .csv file, see: Python Scripting Command Reference
    getVisibleSolidAngle(self, viewshed, requestedLayers)
        Get the layers' visible solid angle from the viewshed.
        @param viewshed: The Viewshed . [Analysis]
        @param requestedLayers: An array of layers . [sequence of ]
        @return: result. [sequence of float]
        @example:
        # get the Solid Angles of the Viewshed per Object Layer
        viewshed = ce.getObjectsFrom(ce.scene, ce.isViewshed)[0]
        panoramaLayer = ce.getObjectsFrom(ce.scene, ce.withName("'Panorama'"))[0]
        newShapesLayer = ce.getObjectsFrom(ce.scene, ce.isLayer, ce.withName("'New Shapes'"))[0]
        layers = [panoramaLayer,newShapesLayer]
        solidAngles = ce.getVisibleSolidAngle(viewshed, layers)
        print "Panorama  : ", solidAngles [0], " steradians"
        print "New Shapes: ", solidAngles [1], " steradians"
KerryKang1
New Contributor II
Hello Thomas,
Thank you for your response. getVisibleSolidAngle function worked perfectly.
Regards,
