CityEngine Scene with WGS84 EPSG:4326
988
02-23-2025 07:30 AM
KennethLindhardt1
I want to export my CityEngine models directly to WGS84 Is it possible? I want to export for example gltf models (glb) with the  information about the placement in WGS84, but in that case I would expect the scene to be in EPSG:4326 which is not available or
I can't find it on the list.
Is it even possible?
Thanks
DanPatterson
MVP Esteemed Contributor
are you trying to create a local or global scene?
Scenes—ArcGIS Pro | Documentation
you could emulate the tutorial with your data
Convert a map to a scene—ArcGIS Pro | Documentation
... sort of retired...
KennethLindhardt1
Thank you Dan.
No, it was directly from CityEngine.
I will update my post more meaningful 🙂
JonasObertuefer
Hi @KennethLindhardt1,
WSG84 lat/lon coordinates are not supported in CityEngine.
Where do you want to have the assets in the end? You will for sure need an additional tool in the process for conversion.
Best
Jonas
ThomasFuchs
Have you tried using CGA to report the spherical latitude/longitude coordinates (WGS84) of the scope's origin with the getGeoCoord function? Tutorial 12: Scripted report export—ArcGIS CityEngine Resources | Documentation then shows you how to write out a file with positioning info for each exported Model.
