CityEngine rail rule???... please help me :)
8690
21
01-22-2016 08:06 AM
AndréLevesque
New Contributor III
Hi folks,
I downloaded the following rule this morning and cant seem to get it to work for me... it appears as though the rule cannot find the texture files associated to it...
Is there somewhere in the code of the cga file that I have to add a path or something?
Link to the rule: Rail rule for streets?
Matthias Buehler​... can you give me advice?
SheylaSantana
New Contributor III
Many thanks, Cheryl!
SheylaSantana
New Contributor III
Cheryl Lau,
Any idea of why I can't see the obj in my scene? The rule has no error and it applies fine to my train rail but it doesn't apply any texture.
SheylaSantana
New Contributor III
Hello, Cheryl.
I have talked with Matt about this trail rule. He told me that in order to the rule work, I need the *.mtl file and texture. Do you still have these files? The zip you sent me just have the *.cga and the *.obj.
Matt is sending you a hello!
Thank you,
Sheyla
CherylLau
Sorry, I do not have the .mtl files.
Maybe you could just apply a color instead?
SheylaSantana
New Contributor III
Hi, Cheryl.
Thank you for your reply!
I will try to figure out something else. If I can't, I will apply colors.
Thanks!
SheylaSantana
New Contributor III
Problem solve! Many thanks for everyone's help! Specially matthiasBuehler‌! You are awesome!
MatthiasBuehler
Occasional Contributor III
I'm glad I could help!
Matt
Matthias Buehler
Founder, vrbn
www.vrbn.io
Joao_PedroMarques
New Contributor III
Is it possible to get the .mtl file?
Thank you!
SheylaSantana
New Contributor III
Sure, Joao.
See the rule attached.
Sheyla
Joao_PedroMarques
New Contributor III
Thank you, Sheyla.
Everything is working now.
